Accelerating Protons in a Particle Accelerator
Protons in a particle accelerator are accelerated through a potential difference of 5,000 V, and they pass between deflecting plates with a potential difference of 1,500 V. The kinetic energy of the protons can be calculated using the relationship between potential difference and energy, where V = Energy/Q. To find the velocity of the protons, the kinetic energy formula, Energy Kinetic = 1/2 mv^2, is applied, using the mass of the proton. The approach combines understanding electric fields and forces with the definitions of potential difference and kinetic energy. This method effectively determines the speed of the protons after acceleration.
pokeefer
Protons are being accelerated through a potential difference of 5,000 V in the gun of a particle accelerator. They must pass between two parallel deflecting plates that are 0.06 m long and 0.02 m apart with a potential difference between them of 1,500 V
Ep = kQ1Q2 / d^2
E= V/d
F = QE
V = Change in Ep / Q
I = Q/t
V = kQ / d
First part asks me:
What is the kinetic energy of protons leaving the gun?
What do i do?
In all these acceleration-through-potential-difference problems, there are just two approaches. The first has all the details:
potential dif causes E field which causes F on electrons which causes them to accelerate which increases their velocity. You can write a basic formula for each "causes" and combine them in a chain to find any of those quantities given any other.
The second approach is a big shortcut that often finds what you want. Use the definition of potential difference: it is the energy given (or taken) from each charge, V = Energy/Q. Quite often you want the speed of the charge so you replace Energy with the KE formula.
So would I do something like this?
V = Energy Potential / Q
V = Energy Kinetic / Q
5,000 v = Energy Kinetic / (1.6 x 10^-19)
Then to find velocity you do:
And in the mass you put the mass of the proton (1.67 x 10^-27) ?
Just want to make sure.
It all sounds good!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
