What Does the Slope Represent in a Force vs. Acceleration Graph?
  • Thread starter Thread starter Fequals
    Acceleration Mass
In a Force vs. Acceleration graph, the slope represents the mass of an object, derived from the equation F=ma. The force is plotted on the Y-axis while acceleration is on the X-axis. This relationship shows that mass can be calculated as the ratio of force to acceleration. Rearranging the formula allows for different graphing approaches, but the fundamental interpretation of the slope remains consistent. Understanding this concept is crucial for analyzing the dynamics of motion.
Fequals
What does the slope of acceleration and mass mean?
What would be on the Y axis and X axis?
F=ma. m=F/a, which shows that if you use the force applied on the y-axis, with the acceleration on the x-axis, the mass of the object will merely be the slope. You can rearrange that formula in other manners if you want to graph it differently.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
