Calculating Average Velocity for a Car with Changing Acceleration and Direction
The discussion focuses on calculating the average velocity of a car that accelerates from rest with changing directions. The car accelerates west at 5.0 m/s² for 10 seconds, covering 250 meters, and then continues northeast for another 10 seconds, resulting in a total displacement of 750 meters. The solution involves breaking down the displacement into x and y components to accurately determine the car's final position. The average velocity is calculated using the formula for average velocity, which is average displacement divided by time. The key takeaway is the importance of vector components in solving problems involving changing acceleration and direction.
jelly1500
[SOLVED] acceleration and velocity
1. Homework Statement
EXACT PROBLEM:
A car accelerates from rest W at 5.0m/s2 for 10.0s, then continues this acceleration NE for another 10.0s. What is the average velocity of the car for its journey to its position after 20.0s? 2. Homework Equations
average velocity=average displacement/time
Delta x=Vit + 1/2at^2
Vf=Vi+at
3. The Attempt at a Solution
First, I found Delta x and Vf for the west vector than found Delta x for the NE vector. Then I tried to find the displacement using Pythagoreans theorem but it was not the correct answer.
Where's the car after 10 s?
Now where is it? What's the total distance displacement from the origin?
after the first 10 sec., its 250 meters away, then after the second 10 sec., its 750 meters
What's the exact location?
oh, I get it! I'm supposed to break in down into it's x and y components. Thank you so much!
