Acceleration as a function of distance to Velocity?
The discussion focuses on a physics problem involving a block on an inclined surface attached to a spring. The initial acceleration of the block is derived as a = kΔx/m - gsinθ - μkgcosθ, with Δx representing spring compression. The acceleration becomes zero when the spring is compressed by l(sinθ + μkcosθ). Participants suggest using energy conservation instead of integrating the acceleration equation to find the speed at the point of zero acceleration. The conversation highlights the complexity of integrating acceleration without time dependence and explores alternative problem-solving methods.
Berdi
A block of mass m lies on a rough surface, inclined at an angle \theta to the horizontal. It is attached to a spring of force constant k; the other end of the spring is fixed to point on the table below the block. The coefficient of static friction between the block and the surface of the table is \mu s and the coefficient of kinetic friction is \muk< \mus
(the friction between the spring and the table is negligible).
There are a lots of parts to this question, but I'll post the relevant parts for the time being:
(l is mg/k)
i)Find the initial acceleration of the block;
ii)Show that the acceleration is zero when the spring is compressed by l(sin\theta +\mu_{k}cos\theta)
iii) Find the speed v0 at this point
Is where I get stuck.
I have found the inital acceleration to be given by a = k\Delta x/m -gsin\theta - \mu_{k}gcos\theta
where \Delta x is the compression of the spring.
And I believe this to be correct as part ii) works out.
I understand that the velocity would be the integral of the acceleration, but I'm confused due to the acceleration equation I have doesn't seem to involve time, so I'm not sure how to begin integrating it.
Rather than try to integrate the acceleration equation, use energy conservation.
Okay, I'll give that a try. Thanks!
