How Far Will the Ball Strike the Opposite Wall?
A ball is thrown from a building toward another building 50 m away with an initial velocity of 20 m/s at a 40° angle. The horizontal and vertical components of the velocity are calculated as 15.3 m/s and 12.9 m/s, respectively. The time taken for the ball to reach the opposite wall is determined to be 3.2 seconds. The discussion emphasizes the importance of consistency when choosing the sign for acceleration due to gravity, which can be treated as either positive or negative depending on the chosen coordinate system. Ultimately, clarity in the direction of measurements is crucial for accurate calculations.
roam
A ball is thrown from the top of one building toward a tall building 50 m away. The initial velocity of the ball is 20 m/s, 40° ABOVE HORIZONTAL. How far above or below its original level will the ball strike the opposite wall?
v_{ix} = 20 cos 40° = 15.3 m/s
v_{iy} = 20 sin 40° = 12.9 m/s
Using x = v_{x}t to find time;
50 = 15.3 t => t = 3.2 seconds.
We use y = v_{iy}t + \frac{1}{2}a_{y}t^2 to find How far above or below its original level will the ball strike the opposite wall;
Now I don't know wether I should take acceleration due to gravity, a = 9.8 as positive or negative for this. (What about viy = 12.0?)
12.9 \times 3.27 + \frac{1}{2} \pm 9.8 \times 3.27 ?
Thanks.
… be consistent …
Hi roam! :smile:
Either … but you must be consistent!
Decide whether you're going to measure y upward or downward.
If downward, then of course g is +9.8, but viy is -12.
If upward, then g is -9.8, but viy is +12. :smile:
Yes, thank you, Tiny tim. I had to make sure since I was skeptic about this.
I understand how it goes now, thanks. :smile:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
