What was the speed of Sputnik I at its perigee?
In summary, the gravitational potential energy of the orbiting satellite is converted to kinetic energy as it oscillates.
ChloeYip
93
Sputnik I was launched into orbit around Earth in 1957. It had a perigee (the closest approach to
Earth, measured from Earth's center) of 6.81 × 106 m and an apogee (the furthest point from
Earth's center) of 7.53 × 106 m. What was its speed when it was at its perigee? The mass of Earth
is 5.97 × 1024 kg and G = 6.67 × 10- 11 N ∙ m2/kg2
F=GMm/r2 F=mv2/r
As energy is also conserved. mv(for perigee)/2-GMm/7.53*106=mv(for apogee)/2-GMm/6.81*106
But how can I find v(for apogee)? Thus v(for perigee)?
I can't find the MC answer which is 7840m/sSimilar thread:
https://www.physicsforums.com/threads/orbit-around-the-earth.867945/
http://www.enotes.com/homework-help/sputnik-was-launched-into-orbit-around-earth-1957-566404
Thanks
There's another conservation law that will help here.
Angular momentum? L=rp=rmv
But still i need to find v for apogee... ehich i don't know how to get the answer avoiding this unknown variable...
Yes, angular momentum is conserved over the whole orbit. What does that tell you about the angular momentum at both apogee and perigee? Can you express that as an equation?
Can you determine the period of the orbit from what you are given? And if so, what does that give you?
(a=apogee,p=perigee,r=radius,v=velosity)
ra x va = rp x vp
Right? Without vp, how to find va?
T=2(pi)/(angular velosity) = 2(pi)r/(average v)?
ra x va = rp x vp
This gives you one relationship between va and vp. Energy conservation gives you another. Two equations, two unknowns.
ChloeYip said:
T=2(pi)/(angular velosity) = 2(pi)r/v?
Do you agree with this?
What is r and what is v?
Thanks
Thanks
If the orbit were circular then I'd agree. But the velocity and radius both vary over time for an elliptical orbit.
Use the conservation laws: energy and angular momentum.
Thanks
Not quite what I was looking for. There is a fairly direct way to get the answer to the problem, but it assumes some knowledge of the nature of orbits. I was trying to gauge just how much you knew about orbits in order to know in what direction to lead you in.
Angular momentum: Rmva=rmvp
Energy: 0.5ka^2 ; 0.5mv^2; -gMm/r => how should i arrange them?
Thanks
I have only little time left before my rxam is coming... hope you can tell me the sooner the better for me to try and understand them... thank you very much.
Okay. Note that the m's can cancel.
Apply energy conservation for the two orbit locations.
I know i should use energy conservation... but how to arrange them? If 0.5k(ap)^2+0.5m(vp)^2+gMm/r=0.5K(aa)^2+0.5m(va)^2+GMm/r
How come there are so many variable?! Am i having something wrong?
So how can i arrange them?
Thanks...
(Only little time left from test...)
I don't know what your "k" terms are meant to represent. What type of energy do they correspond to? What is k?
You need to get your signs right for the gravitational potential energy. Gravitational potential energy in this context takes its reference point at infinite distance, so its sign is always negative.
You have two given locations, apogee and perigee, for which you have separate orbit radii. Be sure to identify them in your equation with separate variable names.
K is spring constant, as such the planet is oscillating like a spring
It is correspond to elastic potential energy
There's no spring here. The "spring" action of the orbit is accounted for by the trading of gravitational potential energy and kinetic energy.
To the extent that the satellite oscillates in its orbit, it is a result of the gravitational attraction term you already have in the equation, not from some mysterious piece of elastic tethering it to Baikonur.
Besides, gravitation follows an inverse square law of attraction, while elastic follows a linear law.
Likes ChloeYip
Thank you very much.
I can find the answer now.
Related to What was the speed of Sputnik I at its perigee?
1. What is acceleration due to gravity?
Acceleration due to gravity is the rate at which an object falls towards the Earth due to the force of gravity.
2. How is acceleration due to gravity measured?
Acceleration due to gravity is typically measured using an accelerometer, which is a device that measures the acceleration of an object. It can also be calculated using the equation a = F/m, where a is acceleration, F is force, and m is mass.
3. What is the acceleration due to gravity on Earth?
The acceleration due to gravity on Earth is approximately 9.8 meters per second squared (m/s²). This value may vary slightly due to factors such as location and altitude.
4. Does acceleration due to gravity change for different objects?
No, the acceleration due to gravity is constant for all objects, regardless of their mass. However, objects with larger masses will experience a greater force of gravity due to their mass.
5. How does altitude affect acceleration due to gravity?
As altitude increases, the acceleration due to gravity decreases slightly. This is because the distance between the object and the center of the Earth increases, reducing the force of gravity acting on the object.
22K
11K
