Acceleration of a block on the floor
  • Thread starter Thread starter iamkristing
    Acceleration Block
The discussion focuses on calculating the acceleration of a block on a floor when a force is applied at an angle. The initial approach involved setting forces in equilibrium, which was incorrect for determining acceleration. The correct method requires comparing the applied horizontal force with the maximum static friction to establish if the block moves. If the block does accelerate, kinetic friction should be used to find the acceleration. The importance of correctly identifying the forces and their effects on motion is emphasized for accurate calculations.
iamkristing
The figure below shows an initially stationary block of mass m on a floor. A force of magnitude F=0.540mg is then applied at upward angle θ = 21°.
(a) What is the magnitude of the acceleration of the block across the floor if (a) s = 0.600 and k = 0.500?
(b) What is the magnitude of the acceleration of the block across the floor if s = 0.400 and k = 0.300?
F=ma and F=s(N) or F=k(N)
Well i drew a Free Body Diagram and found the forces in the x and y direction:
x: F(s)-Fcos(21)=0
y: mg-Fsin(21)-N=0
Then i solved for F(s)=Fcos(21)=0.54mg(cos(21))=4.94m
then i used F=s(N) to solve for N
N=8.233m
Then i set F=ma and F=s(N) equal and solved for a
a=8.233(.500)=4.11
I repeated the same steps for B...but the answers are not correct. Any help at all will be appreciated!
iamkristing said:
x: F(s)-Fcos(21)=0
This assumes equilibrium, that a = 0. Not good.
y: mg-Fsin(21)-N=0
Good. Use this to solve for N and thus compute the friction force.
The first thing to figure out is: Does it move? Compare the applied horizontal force with the maximum static friction.
If it accelerates, then use the kinetic friction to find the acceleration.
Why have you set up the initial equation to be zero? For it to accelerate there has to be some sort of force there.
