Acceleration of a block with static & kinetic friction
A 10kg block experiences a horizontal force of 30 N while at rest, with static and kinetic friction coefficients of 0.33 and 0.20, respectively. The maximum static friction force is calculated to be 32.373 N, which exceeds the applied force, indicating the block does not slide. The discussion clarifies that static friction must be overcome before kinetic friction is considered in motion analysis. If the applied force were greater than the static friction, kinetic friction could then be calculated using Newton's second law. Understanding the sequential role of static and kinetic friction is crucial for accurately determining the block's motion.
ammcl30
A 10kg block is at rest on the floor, and then a force of 30 N pushes on the block horizontally. If the coefficient of static friction between the block and the floor is μs= 0.33 and the coefficient of kinetic friction between the block and the floor is μk= 0.20, what is the acceleration of the block, if it slides?
Answer choices:
A. 0.23 m/s^2
B. 1.04 m/s^2
C. 3.00 m/s^2
D. 0.85 m/s^2
E. The block does not slide
The only equation I used was Fx=ma,x. Because the block is not moving in the y direction there is no need to calculate the force in that direction.
Fx=ma,x
μk-μs= (10kg)a
(.20)-(.33)=(10kg) a ======> a= -.13/10 ==> a= -0.13 or E. The block does not slide
Although I obtained an answer I'm not sure that my set up is right and it was more of a lucky guess. Any help is appreciated!
It is true that the block does not slide. Since The maximum static friction is given by μs(mg), plugging the values in gives 0.33(10)(9.81)= 32.373N hence you would need a force greater than 32.373N to be able to move it in the first place. Only after movement will the kinetic friction be used.
Thank you for answering but this leads me to a question. Why do we only account for the static friction and not the kinetic friction? Don't both of these factor into the overall movement of an object?
Both frictions do, but it's more like they act at different times. You first see if the force can overcome static friction -- in this case it doesn't, so you don't consider kinetic friction. At other times the applied force overwhelms static friction and so kinetic friction starts acting. So since static friction always works first, this is what you calculate first, and then move on if necessary.
A graph of the force of friction (both static and kinetic) versus applied force essentially looks like a linear increase in static friction (more friction as you push harder and harder for something to move), and then the friction suddenly drops when the force becomes great enough. So both frictions matter in the movement, but essentially they can be divided and analyzed separately and at different times.
That makes so much more sense thank you! So theoretically if after I calculate the static friction and it was less than the applied force, I could solve the kinetic friction using Newtons 2nd law and kinematics. Correct?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
