Calculating Velocity and Displacement Using Acceleration Formula | Train Example
  • Thread starter Thread starter MagMag
    Acceleration
To solve for the train's velocity at t=4 s and the displacement from t=2 s to t=4 s, start by recognizing that the acceleration a=2t can be expressed as dv/dt. By integrating this with respect to time, the velocity function can be derived, incorporating the initial velocity of 180 km/h at t=2 s. Once the velocity function is established, it can be integrated again to find the displacement over the specified time interval. This approach utilizes calculus rather than traditional kinematics equations, emphasizing the importance of integration in solving the problem. The calculations will yield both the final velocity and the total displacement for the train.
MagMag
I'm a little stuck on this:
Suppose that the acceleration of a train during the interval of time from t=2 s to t=4 s is a=2t m/s^2, and at t=2 s its velocity is 180km/h
Using formulas: Velocity v=ds/dt and acceleration a =dv/dt, determine:
(a) the train’s velocity at t=4 s,
and;
(b) the displacement (change in position) from time t=2 s to t= 4 s
I should really be able to do this but for some reason my mind has frozen so I was hoping for some help or some nudges in the right direction!
Thanks in advance!
and;
Thanks in advance!
Given the way the question is asked, you should approach this as a calculus problem rather than a physics problem, so disregard the typical kinematics equations.
You are given a = 2t and a = dv/dt, so it follows that dv/dt = 2t. You are also given the interval of t = 2 to t = 4. Knowing the basics of integral calculus, how do you find the equation for V? (don't forget to add in the initial velocity)
Once you get the equation for V, and given that V = ds/dt, how do you find an equation for distance travelled?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
