How to Calculate Acceleration for a Car Speeding from 10m/s to 15m/s in 80m"
To calculate the acceleration needed for a car speeding from 10 m/s to 15 m/s over a distance of 80 m, the appropriate equation is vf² = vi² + 2ad, where vf is the final velocity, vi is the initial velocity, and d is the distance. The initial equations provided were not suitable since they assume an initial velocity of zero. The correct approach involves rearranging the equation to solve for acceleration (a). After substituting the known values, the acceleration can be determined. This method effectively addresses the problem of calculating acceleration in scenarios with non-zero initial velocities.
Oceanspire
Poster has been reminded that they need to show some effort when posting schoolwork problems
1. What acceleration would be needed by a car speeding up from 10 m/s to 15 m/s in 80 m?2. The equations I have at my use right now are:
V = at
D = (1/2)(a)(t)^2
T = square root of 2D / A
A = change in velocity / time3. I honestly can't wrap my mind around how to solve this
V = at
D = (1/2)(a)(t)^2
Welcome to PF!
Your equations are valid when the initial velocity is zero. It is not the case in the problem.
Can't you use vf2 = vi2 + 2ad ?
You have vf, vi, d, and now you will have to find a.
Antonius said:
Can't you use vf = vi + 2ad ?
Don't you need to square those velocities ?
sorry
i edited it now (Y)
