Acceleration-velocity-position graph~
  • Thread starter Thread starter P-Illiterate
    Graph
To draw a velocity vs. time graph from an acceleration vs. time graph, calculate the area under the acceleration curve for the desired time interval, which represents the change in velocity. For a position vs. time graph, take the area under the velocity curve, which indicates the change in position over time. The area from t=0 to t=t1 on the acceleration graph provides the velocity at t=t1. Understanding these relationships is crucial for accurately representing motion in graphs. Mastering these concepts allows for effective visualization of an object's motion.
P-Illiterate
How do I draw a velocity vs time graph and a position vs time graph if I'm a given a acceleration vs time graph ?
Thank you :D
Thank you :D
The area under the acceleration vs. time graph gives the velocity at that point. Similarly, the area under the velocity vs. time graph gives the position.
but I still don't get how I draw it in the graph
can someone help mee??!
For example, the area from t=0 to t=t1, will give the velocity at t= t1.
