Adding three vectors, why is this not right?
  • Thread starter Thread starter rickbusiness
    Vectors
The discussion centers on the addition of three vectors A, B, and C, with specific magnitudes and angles provided. The calculations for the x and y components of each vector are detailed, leading to a resultant vector R with a magnitude of approximately 22.6 and an angle of 68.9 degrees. A key point of confusion arises from the interpretation of vector C's direction, with a suggestion that it may be oriented differently than initially assumed. Ultimately, it is clarified that the problem requires finding A - B + C instead of A + B + C, which resolves the discrepancies in the calculations. This highlights the importance of carefully reading vector addition problems to ensure accurate results.
rickbusiness
http://postimage.org/image/gcb728073/
A=47.2 at 54.3deg above the x axis, B= 23.5 at 34.4 above the -x axis, C=30.5 along the -y axis.
A+B+C=(Ax+Bx+Cx)+(Ay+By+Cy) = R
R=√(Rx2+Ry2) = 22.63
θ=tan-1Ry/Rx = 68.9deg
I just thought of the possibility that c may be at 90 deg instead of 270. As in pointing upwards along the neg y axis. Is there something i missed?
What values and signs are you getting for the x and y components of the three vectors? C points down with a magnitude of 30.5.
Ax=Acosθ=47.2cos(54.3) = 27.5
Ay=Asinθ=47.2sin(54.3) = 38.3
Bx=Bcosθ=23.5cos(180-34.4) = -19.4
By=Bsinθ=23.5sin(180-34.4)= 13.3
Cx=Ccosθ=30.5cos(270)=0
Cy=Csinθ=30.5sin(270)=-30.5
Rx= 27.5-19.4+0=8.1
Ry=38.3+13.3-30.5=21.1R=√(8.12)+(21.12)=22.6
θ=tan-1(21.1/8.1)=68.9deg
Ive tried rounding to different numbers of decimal places and not rounding till the end but I still had no success and I don't know why.
Rx= 27.5-19.4+0=8.1
The problem doesn't say to find A+B+C. It says to find A-B+C.
hahaha thanks!
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
