Proof of Hermiticity of Adjoint Operators
  • Thread starter ultimateguy
  • Tags
    Operators
In summary: Lemma: If A and B are operators, then(A+B)^{\dagger}=A^{\dagger}+B^{\dagger}and(\lambda A)^{\dagger}=\lambda^*A^{\dagger}Proof: Let \psi and \phi be vectors in the domain of A and B. Then\langle(A+B)\psi,\phi\rangle=\langle A\psi,\phi\rangle+\langle B\psi,\phi\rangleIf \psi is also in the domain of A^{\dagger}, then\langle A\psi,\phi\rangle=\langle \psi,A^{\dagger}\phi\rangleand so\langle(A+B)\
ultimateguy
125
A is a non-Hermitian operator. Show that
[tex]i(A-A^t)[/tex]
is a Hermitian operator.
[tex]\int \psi_1^*\L\psi_2 d\tau=\int (\L\psi_1)^*\psi_2 d\tau[/tex]
[tex]\int \psi_1^*A^t\psi_2 d\tau=\int (A\psi_1)^*\psi_2 d\tau[/tex]
[tex]\int \psi_1^*i(A-A^t)\psi_2 d\tau[/tex]
[tex]=\int \psi_1^*iA\psi_2 d\tau + \int \psi_1^*(-iA^t)\psi_2 d\tau[/tex]
[tex]=\int (iA^t\psi_1)^*\psi_2 d\tau + \int ((-iA)\psi_1)^*\psi_2 d\tau[/tex]
[tex]=\int i((A-A^t)\psi_1)^*\psi_2 d\tau[/tex]
Is this right? The signs are wrong in the third line, but taking the i out of the complex conjugate brackets fix them. Can I do that?
I am confused. Quick question:
1.) Is [itex]A^t[/itex] supposed to be [itex]A^{\dagger}[/itex], the Hermetian conjugate of [itex]A[/itex]?
Yes, I didn't know the Latex code for it.
Inside the TeX brackets it's \dagger.
Anyway, what you have here is an abstract operator, not a coordinate representation of an operator. So you shouldn't be throwing it into that integral relation. Just use the following:
Let [itex]A[/itex] and [itex]B[/itex] be operators and let [itex]\lambda\in\mathbb{C}[/itex].
[tex](A+B)^{\dagger}=A^{\dagger}+B^{\dagger}[/tex]
[tex](\lambda A)^{\dagger}=\lambda^*A^{\dagger}[/tex]
I just discovered that I wasn't taking the conjugate of the complex value when doing [tex](\lambda A)^\dagger[/tex] in the method above. When I do this, everything actually works out fine.
No, there's a major problem with your solution, and I already told you what it is. You took an abstract operator and treated it as though it were the coordinate representation of an operator. Specifically, you treated it as though it were a first derivative operator (whether you realize it or not). That's the only way you could have mimicked the integration by parts step that you did with the momentum operator (which really is a first derivative operator). You should just use the abstract rules for operators that I quoted.
But I didn't mimic the integration by parts step, I used the definition of an adjoint operator. (Which is the second equation in the list) There's no integration in the method, only substitution.
My solution
I'd say the problem's more involved than it first looks. One's not forced to reduce his analysis to bounded everywhere defined operators on an abstract complex Hilbert space, so the solution is really involved.
So [itex] A:D(A)\rightarrow \mbox{Ran}(A) [/itex] is a densly defined linear operator on an abstract complex Hilbert space [itex] \mathcal{H} [/itex], i.e.
[tex] \overline{D(A)}=\mathcal{H} [/tex] (1)
Therefore its adjoint exists and we also assume that the adjoint is densly defined and therefore its adjoint - [itex] A^{\dagger\dagger} [/itex] exists.
It it crucial to the proof that
[tex] \overline{D(A)\cap D\left(A^{\dagger}\right)}=\mathcal {H} [/tex] (2)
so that its adjoint exists so we can prove that
[tex] i\left(A-A^{\dagger}\right) \subseteq \left(i\left(A-A^{\dagger}\right)\right)^{\dagger} [/tex] (3)
First we tackle the domain question. The "i" multiplying the operators is inessential to the domain issues and therefore can be neglected.
[tex] D\left(A-A^{\dagger}\right)=D(A)\cap D\left(A^{\dagger}\right)\subseteq D\left(A^{\dagger\dagger}\right)\cap D\left(A^{\dagger}\right) [/tex] (4)
since a theorem insures us that, if the double adjoint exists, the double adjoint is an extension of the original operator, i.e.
[tex] A\subseteq A^{\dagger\dagger} [/tex] (5)
which means that
[tex] D(A)\subseteq D\left(A^{\dagger\dagger}\right) [/tex] (6) and
[tex] A\psi =A^{\dagger\dagger}\psi , \forall \psi\in D(A) [/tex] (7)
There's another theorem in Hilbert space that says
[tex] \left(A^{\dagger}-A^{\dagger\dagger}\right)\subseteq \left(A-A^{\dagger}\right)^{\dagger} [/tex] (8)
which means that
[tex] D\left(A^{\dagger}-A^{\dagger\dagger}\right)=D\left(A^{\dagger}\right)\cap D\left(A^{\dagger\dagger}\right)\subseteq D\left(\left(A-A^{\dagger}\right)^{\dagger}\right) [/tex] (9)
Compare now (9) and (4). It follows that
[tex] D\left(A-A^{\dagger}\right)\subseteq D\left(\left(A-A^{\dagger}\right)^{\dagger}\right) [/tex] (10)
from which trivially
[tex] D\left(i\left(A-A^{\dagger}\right)\right)\subseteq D\left(i\left(A-A^{\dagger}\right)^{\dagger}\right) [/tex] (11)
So the first part of the proof is done. We're tackling now the ranges/codomains issue. We need to prove that
[tex] i\left(A-A^{\dagger}\right) \chi =\left(i\left(A-A^{\dagger}\right)\right)^{\dagger} \chi , \ \forall \chi\in D\left(i\left(A-A^{\dagger}\right)\right) [/tex] (12)
Consider the scalar product:
[tex] \langle \psi, i\left(A-A^{\dagger}\right)\chi \rangle , \forall \psi \in D\left(A^{\dagger}\right)\cap D\left(A^{\dagger\dagger}\right) [/tex] (13)
We claim that:
[tex] \langle \psi, i\left(A-A^{\dagger}\right)\chi \rangle =\langle \psi, i\left(A\chi-A^{\dagger}\chi)\rangle=\langle -iA^{\dagger}\psi,\chi\rangle -\langle -iA^{\dagger\dagger}\psi ,\chi\rangle =\langle -iA^{\dagger}\psi,\chi\rangle -\langle -iA\psi ,\chi\rangle [/tex] (14)
by the virtue of (7). Then
[tex] \langle -iA^{\dagger}\psi,\chi\rangle -\langle -iA\psi ,\chi\rangle =\langle i\left(A-A^{\dagger}\right)\psi, \chi\rangle =\langle \psi, \left(i\left(A-A^{\dagger}\right)\right)^{\dagger}\chi\rangle [/tex] (15)
Compare (14) and (15) and we conclude that
[tex] i\left(A-A^{\dagger}\right) \chi =\left(i\left(A-A^{\dagger}\right)\right)^{\dagger} \chi [/tex]
So the second part of the proof is completed. The whole proof is complete. QED.
ultimateguy: In the form of abstract operators, the definition of a Hermitian operator [itex]A[/itex] is [itex]A = A^\dagger[/itex]. You can just use matrix algebra to get your answer. Your second equation in the list that you consider the definition of a Hermitian operator is the follows from the what a Hermitian operator looks like in integral form.
OK, I see that now. I still maintain that you don't have to use that integral relation though. If you want to find the adjoint of that operator, all you have to do is use the rules:
[tex]\left(i\left(A-A^{\dagger}\right)\right)^{\dagger}=-i\left(A^{\dagger}-A^{\dagger\dagger}\right)=i\left(A-A^{\dagger}\right)[/tex]
Related to Proof of Hermiticity of Adjoint Operators
1. What is the concept of hermiticity in mathematics?
Hermiticity is a mathematical concept that describes a property of operators in linear algebra. An operator is considered hermitian if it is equal to its own adjoint. In simpler terms, this means that the operator remains unchanged when its rows and columns are swapped and each element is conjugated.
2. How is hermiticity related to quantum mechanics?
In quantum mechanics, hermiticity is a fundamental property of operators that represent physical observables. This means that the measurement of a physical quantity should not depend on the order in which the measurement is made, and hermitian operators ensure this property.
3. What is the proof of hermiticity for adjoint operators?
The proof of hermiticity for adjoint operators involves showing that the inner product of the operator with its adjoint is equal to the inner product of its adjoint with itself. This is done using properties of inner products and the definition of adjoint operators.
4. Why is the proof of hermiticity important?
The proof of hermiticity is important because it ensures the validity of quantum mechanical calculations. Hermitian operators have real eigenvalues, which correspond to physically measurable quantities, making them essential in quantum mechanics calculations.
5. Are all operators hermitian?
No, not all operators are hermitian. Only a specific set of operators, such as position, momentum, and energy, are considered hermitian. These operators are the ones that represent physical observables and have important applications in quantum mechanics.
  • Quantum Physics
