Advanced vector question incl. parallelepiped
  • Thread starter Thread starter agentnerdo
    advanced Vector
The discussion revolves around solving a vector problem involving the cross product and volume of a parallelepiped defined by vectors A, B, and C. The user expresses confusion about calculating the magnitude of the cross product and the correct interpretation of the symbols used. Clarifications are provided regarding the definitions of the cross product and dot product, emphasizing the importance of understanding these concepts for solving the problem. The user attempts to set up the calculations but makes assumptions about missing components in vector B. Ultimately, they arrive at a partial solution, indicating further assistance may be needed for the remaining parts of the problem.
agentnerdo
Given the three vectors A = 2i + j, and B= i + k, C=4j, find the following
a) |A X B|
b) |A x (B X C)|
c) the volume of the parallelepiped whos concurrent edges rae represented by A B C.
I am stuck on A.
I assume it couldn't be as simple as |(2i+j)(i+k)|?
Once I get the first part I will try b and c myself before asking for more help (which I def will need)
You need some basic definitions before tackling the question. Google "cross product" and "triple scalar product", or if you have a textbook, look them up there. I think the symbol you wrote as X is the cross that denotes the cross product, and I suspect the symbol you wrote as x should really be the dot that denotes the "dot product" (another one to google if you haven't met that yet).
The pipes, those vertical lines, | ... |, in (a) denote what's called the "length", "magnitude" or "norm" of the vector "A cross B". The pipes in (b) denote the "absolute value" of the number "A dot (B cross C)".
I think I am kind of getting it.
Most examples online use three numbers (ie =3i, 5j, 6k)
As such you get a nice little box
In this case, we are missing, for B= any j value, does this mean we assume j=1 for b?
this is what I have so far
i j k
2 1 1 (I assume this is 1, since it is not shown)
1 1 1 (made the assumpetion for j again)
1 4 1
Now, looking at i;
1x1 - 4x1 = -3
i 1-1=0
j ---> 4-1=3
therefore, final answer is 0.
