Against length contraction explanation of magnetism
In summary, when a test charge stands next to a wire, there are coulomb forces between the test charge and the protons of the wire. These forces stay the same until the test charge starts to move, at which point the forces increase due to the decreased distance between the charge and the protons.
jartsa
1,577
138
When a test charge stands next to a wire, there are coulomb forces between the test charge and the protons of the wire.
1: When the test charge starts to move, the Coulomb forces stays the same, because distances from test charge to protons stay the same. There is no magnetism in this case.
2: When the test charge stays still and the wire starts to move, the Coulomb forces increase, because distances from test charge to protons decrease. But we do not call this magnetism. We call it decrease of distance and increase of Coulomb force.
If we ask the test charge, it says there is no difference between the case 1 and the case 2. In both cases the wire looks the same to the test charge.
3: When two test charges placed side by side start to move there is no change of distance, but there is a change of total force between the charges. This case we call magnetism. And we explain the 'magnetism' by the change of the electric fields. Right?
4: And the same change of fields can explain the total force between two wires with opposite currents.
Yes, but in this case we also have a nonzero magnetic field due to the nonzero current from the moving wire, so the increased Coulomb force is counterbalanced by a nonzero magnetic force in the opposite direction. So the net force on the charge is the same.
Yes, but if you only take the Coulomb force into account in case 2, you can't explain why this is true. You need the magnetic force as well.
Yes, because of the current due to the moving charges. Not because of any change in the charges themselves.
Wrong. We explain it by the presence of a nonzero current. Go look at Maxwell's Equations.
Are you talking about a wire with a net charge but no current in the lab frame?
What direction? And by “start to move” are you asking about a sudden acceleration to a constant speed or a gradual acceleration or do you just mean that it is moving inertially? Please describe your scenarios a little better. I am not following you here.
Veritasium explored this very topic in an excellent video on YouTube.
This should answer your questions..
The test charge does not care about magnetic fields, because it's not in any way magnetic, because it's not moving. In the lab frame.
As I said, the test charge does not feel the magnetic field of the moving protons. In the lab frame.
(There was the other case where the test charge was moving in the lab frame and the protons where still in the lab frame, same reasoning applies in that case; no magnetic force felt by test charge in the lab frame, because the test charge is the only charge that is moving in the lab frame)
That is one explanation.
I am still confused about your scenarios. In addition to what I wrote before, when you say “increase of force” are you talking about an increase over time or a comparison to the previous scenario or a comparison to the reference scenario.
I think that @PeterDonis is answering a different question than you think you are asking.
I didn't read any further, because I'm pretty sure this is wrong. The transverse field increases. See for instance wiki, https://en.wikipedia.org/wiki/Classical_electromagnetism_and_special_relativity
The field component of interest is ##E_{\bot}##, you can see from the wiki (or a different reference) that if there is no magnetic field, for a moving charge, ##E'_{\bot} = \gamma E_{\bot}##.
Here's an edited version of post #1:
1: When the test charge is slowly accelerated, the Coulomb forces stays the same, because distances from test charge to protons stay the same, in the lab frame. I mean, there are always some constant number of protons inside some radius around the test charge, in lab frame. There is no magnetism in this case, in lab frame.
2: When the test charge stays still and the wire is slowly accelerated, the Coulomb forces are increasing during the acceleration, in lab frame, because distances from test charge to protons are decreasing during the acceleration, in lab frame. We in the lab frame are observing the length of the wire getting shorter. But we in the lab frame do not call this magnetism. We call it decrease of distance and increase of Coulomb force.
3: When two test charges placed side by side are slowly accelerated, there is no change of distance between the particles, in any frame, but total force between the charges is decreasing during the acceleration, in the lab frame. This case we in the lab frame call magnetism. And we explain the 'magnetism' by the change of the electric fields. Right?
This page is talking about that change of electric fields, in the part entitled Transformation of electrostatic fields:
Magnetism, Radiation, and Relativity
If the wire is uncharged and current-free then the force is zero. If there are electrons present then you cannot just ignore them as they also produce a force and the test charge can only measure the force from the net charge.
The transverse field of a test charge, whose speed is increasing in the lab frame, is increasing in the lab frame?
Yes, but the force exerted on the test charge in the lab frame depends on the electric field of the protons, which stay still in the lab frame in my case number 1.
Jartsa, I don't understand where you are coming from. Are you arguing:
A. Relativity is wrong?
B. Relativity is right, but this calculation is wrong?
C. Relativity and the calculation are right, but it's pedagogical value is low?
D. Something else?
D. Something else?
D. "Hey I noticed some problems with the length contraction explanations" I'm not sure what calculation we are talking about now.
But does this not hold, if a test charge with charge q is in motion:
F=qE
The E there is the field measured in the lab frame, the velocity of the field is zero in the lab frame. And F means force in the lab frame.
I don't think anybody is clear on your scenarios, which is a problem. Do I take it that the two scenarios are meant to be initially identical, with a charge at rest near an un-charged current-carrying wire? Then either (1) the charge starts to move, or (2) the wire starts to move? In which direction?
F=qE
If q is in motion then this is only true if ##\vec B=0##.
But your description says there should be: in case 1 the Coulomb force stays the same, in case 2 it increases. So whatever alternative model you think you are describing, it gives the wrong answer, so it can't be right.
I think that your examples are not correct. I don’t think that the problem is with the explanation.
Besides the incomplete description, one really big issue is that accelerating the charge vs accelerating the wire is physically different. You cannot change from one scenario to the other simply by a Lorentz boost. They are not symmetric. Furthermore, the charge’s perspective is inertial in one case and non inertial in another meaning that the standard Maxwell’s equations will not work in both.
Assuming that the wire is charged with no current and assuming that the test charge is accelerated parallel to the wire and assuming that the wire is infinite and straight (all of which would have been nice for you to clarify) then I agree.
jartsa said:
When the test charge stays still and the wire is slowly accelerated, the Coulomb forces are increasing ... We call it decrease of distance and increase of Coulomb force.
I assume that you mean that the wire accelerates parallel to its length. Having charges accelerating at infinity may bring in some mathematical problems. I would call it increase in charge density.
The laws of physics (Maxwell’s equations) are different.
You can explain the magnetism any number of ways. The one most in keeping with the Purcell explanation would be The Lorentz transform. Those can be used to figure out how forces transform.
So we have explanations of magnetism by length contraction. Usually there are protons that are just standing still, in the lab frame. So there is no length contraction effects there, in the lab frame. Because there is no motion.
And then there are electrons that usually are moving, in the lab frame, but the moving does not affect the density of electrons, in the lab frame. Why the density is not affected, that I will not discuss now.
Then usually we go the frame of moving electrons, where we can observe some length contraction effects. Quite usual is that proton density is increased, if "proton density is increased" is unclear, see this video at time 2:10
As I said usually the protons are standing still in the lab frame, so the protons do not have any magnetic effect on anything, in the lab frame. So now as we have finally managed to find a length contraction effect, it does not correspond to a magnetic effect in the lab frame.
That is why you cannot neglect the electrons if they are present, as I mentioned above in post 9. Please be explicit, are you considering a charged wire or a neutral wire, as I asked you to clarify back in post 3.
Here are the problems I see with your scenarios:
Did not specify the charge in the lab frame
Did not specify the current in the lab frame
Did not specify the geometry of the wire
Did not specify the direction of the acceleration
Used acceleration rather than inertial motion
Used non inertial frames
Did not consider how force transforms
Made incorrect assertions
I remain confused about what you think the problem is. The electrons are responsible for the magnetic field in the lab frame, and they are length contracted (or at least their spacing is). In the electron frame the protons are responsible for the magnetic field, and they are length contracted (or at least their spacing is). Also in this frame there is an electric field because the charge densities don't cancel.
Length contraction is part of how E and B fields transform between different frames.
See this diagram from:
https://www.physicsforums.com/threa...-of-electrostatics.577456/page-3#post-3768045
##\newcommand{\dd}{\mathrm{d}}##
##\newcommand{\vv}[2]{\begin{pmatrix} #1 \\ #2 \end{pmatrix}}##
##\newcommand{\vvv}[3]{\begin{pmatrix} #1 \\ #2 \\ #3 \end{pmatrix}}##
##\newcommand{\vvvv}[4]{\begin{pmatrix} #1 \\ #2 \\ #3 \\#4 \end{pmatrix}}##
##\newcommand{\bvec}[1]{\boldsymbol{#1}}##
I think this confusion is again due to the strange attempt to be didactic by Purcell in volume 2 of the Berkley Physics Course. It's very hard to read and very confusing. Of course electrodynamics is in itself a relativistic theory from the very beginning although Maxwell and the Maxwellians didn't know before Einstein completed the picture with his famous article in 1905.
The right way to clearly teach the subject in my opinion is to start with an introduction of Minkowski space and four-vectors and four-tensors as well as four-vector/tensor fields. Then the behavior of components wrt. to inertial reference frames under Lorentz transformations is clearly stated, and you learned a lot about the somewhat unfamiliar kinematics implied by the relativistic spacetime structure.
Then your troubles are solved very easily: The source of the electromagnetic field is the electric-current four-vector field with components
$$(j^{\mu})=\vv{c \rho}{\vec{j}},$$
where ##j^{\mu}## in fact is an abbreviation for ##j^{\mu}(x)##, where ##x=(x^{\mu})=(c t,\vec{x})## is the space-time four-vector.
If you have a Lorentz-transformation matrix ##\hat{\Lambda}={\Lambda^{\mu}}_{\nu}## with ##x'=\hat{\Lambda}(x)## the transformation for the four-current is as for any other four-vector field:
$$j^{\prime \mu}(x')={\Lambda^{\mu}}_{\nu} j^{\nu}(x)={\Lambda^{\mu}}_{\nu} j^{\nu}(\hat{\Lambda}x').$$
The electromagnetic field is described by the antisymmetric Faraday tensor with components ##F_{\mu \nu}##. The time-space components can be uniquely mapped to the electric field components, and the space-space components to the magnetic field components as seen from the perspective of an observer at rest with respect to the chosen inertial reference frame. Also its transformation properties are clear from the Minkowski-space tensor formalism
$$F^{\prime \mu \nu}(x')={\Lambda^{\mu}}_{\rho} {\Lambda^{\nu}}_{\sigma} F^{\rho \sigma}(\hat{\Lambda}^{-1} x').$$
The Lorentz-force law for a charged particle moving in a given electromagnetic field can also be written in manifestly covariant notation, and thus also there you can't have any doubts concerning how the components transform under Lorentz transformations.
For this you introduce proper time of the particle by
$$c^2 \mathrm{d} \tau^2=\mathrm{d} s^2=\eta_{\mu \nu} \mathrm{d} x^{\mu} \mathrm{d} x^{\nu},$$
where ##(\eta_{\mu \nu})=\mathrm{diag}(1,-1,-1,-1)## (west-coast convention as in the majority of HEP physicists' textbooks and papers) are the components of the Minkowski pseudo-scalar product. Then the manifestly covariant equation of motion reads
$$m \frac{\mathrm{d}^2 x^{\mu}}{\mathrm{d} \tau^2}=K^{\mu}=\frac{q}{c} F^{\mu \nu}(x) \frac{\mathrm{d} x^{\nu}}{\mathrm{d} \tau}.$$
Since ##\mathrm{d} \tau## is a scalar and ##x^{\mu}## is a vector under Lorentz transformations so is the Minkowski-Lorentz force ##K^{\mu}##, and thus its components transform as any four-vector components.
So the little effort of 1-2 lecture hours to introduce this tensor calculus, using Einstein's original arguments, postulating the special principle of relativity and the invariance of the speed of light in any inertial reference frame, is paid back by a very lucid discussion of the physics of electromagnetism and any other subject of relativistic physics (e.g., relativistic hydrodynamics and transport theory, relativistic QFT), and it's also only a small step towards General Relativity, which admittedly is the most beautiful theory discovered yet!
I agree, but I wouldn't blame Purcell for that. I would blame Einstein himself, or more precisely the usual practice of teaching introductory special relativity in the form Einstein himself introduced it in 1905. It was Minkowski, not Einstein, who later introduced the 4-dimensional view of relativity, and Einstein even didn't like it in the beginning. (Later he accepted it in the formulation of his general relativity.) My point is, given that special relativity is presented to students in a non-covariant non-4-dimensional form, the ugly Purcell pedagogy of electrodynamics looks "more natural" than the elegant covariant formulation.
I don't think one should blame Einstein, who used the mathematical machinery used at his time. E.g., although Heaviside had introduced the much more clear vector calculus obviously physicists still used to even write Maxwell's equations in components in a very cumbersome way, and this is what Einstein did in his famous paper. Minkowski, however, came with this mathematical analysis already in 1908, and since then textbook writers have had enough time to adopt it. There's no excuse for confusing students simply by being too lazy to write new textbooks and not just copying old ones! Purcell would have an impact in the better direction, had he not overdone the task to make things "pedagogical".
For me special relativity also has been an enigma, until I discovered Landau-Lifshitz vol. II at some time in my 4th semester, where we had to suffer a boring presentation of classical electrodynamics in the old-fashioned way starting from electrostatics in all detail, with the result that at the end of the semester the professor had barely touched magnetostatics and then was shocked himself that he hadn't ever talked about waves, let alone relativity ;-(. That's why together with some other nerdy theory addict students we studied Landau-Lifshitz vol. II on the side, which was much more fun than the traditional lecture presented to us.
They had enough time, but the fact is that they didn't do it. My point is that Purcell is not the only guy who didn't do it. All introductory textbook writers, who include some introductory special relativity, are equally guilty.
Why is beginning relativity taught the way it is? I don't know. Perhaps because it is believed that 4-dimensional thinking is too difficult for most beginning students. After all, at the beginning it was too difficult even for Einstein.
Suppose that you must choose between the following two ways to teach electrodynamics:
1) Purcell way, which uses special relativity from the beginning, but in the old-fashioned non-covariant form.
2) Traditional historical semi-empirical way, in which Maxwell equations are obtained without using special relativity at all.
Which one would you choose?
I'd never ever teach E&M like Purcell. Of course, maybe in Germany the strategy is a bit different. In our theory course you get an introduction to SR already in the 2nd semester (analytical mechanics). Then, in principle, you can teach electromagnetics, which is taught in the 3rd semester in the theory course, from the very beginning as a relativistic theory, and some of our professors do so. It, of course, also depends on the addressed audience. For people who haven't ever heard about electromagnetism before, you'd have to start in the traditional way and carefully explain the idea behind fields in the usual operational way first. Usually this is covered by the experimental course, where E&M usually is treated in the 2nd semester. Of course, in any case at the beginning should be introduced the full Maxwell equations as pioneered by Heinrich Hertz. I'd be sparse on history, but from time to time tell about the people after whom the phenomena/formulae are named :-)).
The best theory book on the traditional way, in my opinion, still is Sommerfeld's Lectures vol. III. Of course, I'd never use the pseudo-Euclidean ##\mathrm{i}c t## convention of the metric but substitute it with Minkowski. The best books using the relativistic approach are Landau+Lifshitz vol. II or the book by Melvin Schwartz.
1. What is the "Against length contraction explanation of magnetism" theory?
"Against length contraction explanation of magnetism" is a theory proposed by physicist Hendrik Lorentz in the late 19th century. It states that the phenomenon of magnetism can be explained by the contraction of the length of objects moving through the ether, a hypothetical medium that was believed to permeate all of space. This theory was later disproved by Albert Einstein's theory of special relativity.
2. What evidence supports the "Against length contraction explanation of magnetism" theory?
The main evidence for this theory was based on the results of the Michelson-Morley experiment, which aimed to detect the existence of the ether. The experiment found that the speed of light was constant regardless of the direction of motion, which contradicted the concept of length contraction proposed by Lorentz. Additionally, the theory was unable to explain the behavior of particles at high speeds, which was later explained by Einstein's theory.
3. How does the "Against length contraction explanation of magnetism" theory differ from other theories of magnetism?
The "Against length contraction explanation of magnetism" theory differs from other theories of magnetism in that it relies on the existence of the ether and the concept of length contraction. Other theories, such as the modern theory of electromagnetism, do not require the presence of the ether and can fully explain the phenomenon of magnetism without the need for length contraction.
4. Why was the "Against length contraction explanation of magnetism" theory ultimately disproved?
The "Against length contraction explanation of magnetism" theory was ultimately disproved by Einstein's theory of special relativity, which provided a more comprehensive and accurate explanation for the behavior of particles at high speeds. Einstein's theory also did not rely on the existence of the ether and did not require the concept of length contraction, making it a more widely accepted and supported theory.
5. Are there any modern theories that support the "Against length contraction explanation of magnetism" theory?
No, there are no modern theories that support the "Against length contraction explanation of magnetism" theory. The theory has been disproved by numerous experiments and has been replaced by more comprehensive theories such as special relativity and the modern theory of electromagnetism. However, some aspects of the theory are still studied and used in certain fields, such as Lorentz transformations in special relativity.
  • Electromagnetism
