Solving Complex Velocity from Particle Falling in Gravity
The discussion revolves around deriving the equations of motion for a particle falling under gravity with air drag proportional to the square of velocity. The initial derivation leads to a complex velocity, prompting concerns about the sign of the drag force in the equations. It is clarified that the drag force should be subtracted from gravitational force, leading to the correct formulation of m(d²x/dt²) = mg - k(dx/dt)². The participants also note that either the drag force or the potential energy sign can be adjusted to yield correct results, but not both simultaneously. Ultimately, the confusion stems from the directionality of forces and the definitions of the coordinate system used in the derivation.
fobos3
I'm trying to derive the equations of motion for a particle falling in a uniform gravitational fill with air drag proportional to the square of velocity. However I'm getting the velocity as a complex number. Here is what I've done
The force of friction is F=-k\left(\dfrac{dx}{dt}\right)^2\dfrac{\textbf{v}}{||\textbf{v}||}=-k\left(\dfrac{dx}{dt}\right)^2
We put the particle stationary at x=0
The Lagrangian is \mathcal{L}=\dfrac{1}{2}m\left(\dfrac{dx}{dt}\right)^2-mgx
\dfrac{d}{dt}\left(\dfrac{\partial \mathcal{L}}{\partial \dot{x}}\right)-\dfrac{\partial \mathcal{L}}{\partial x}=-k\left(\dfrac{dx}{dt}\right)^2
m\dfrac{d^2 x}{dt^2}+mg=-k\left(\dfrac{dx}{dt}\right)^2
If we put c=\dfrac{k}{m}
\dfrac{d^2x}{dt^2}+c\left(\dfrac{dx}{dt}\right)^2+g=0
We put p=\dfrac{dx}{dt}
We have \dfrac{d^2x}{dt^2}=\dfrac{dp}{dt}=\dfrac{dp}{dx}\dfrac{dx}{dt}=\dfrac{dp}{dx}p
The differential equation becomes
\dfrac{dp}{dx}p+cp^2+g=0
\dfrac{p}{cp^2+g}\dfrac{dp}{dx}=-1
\int\dfrac{p}{cp^2+g}\,dp=-x
To solve the integral we put u=cp^2+g
\dfrac{du}{dp}=2cp
p=\dfrac{1}{2c}\dfrac{du}{dp}
\dfrac{1}{2c}\int \dfrac{1}{u}\,du=-x
\int \dfrac{1}{u}\,du=\ln |u|=\ln u because u>0
\dfrac{1}{2c}\ln (cp^2+g)+A=-x
A(cp^2+g)=e^{-2cx}
At t=0,x=0,p=0
Ag=1
A=\dfrac{1}{g}
\dfrac{c}{g}p^2+1=e^{-2cx}
p^2=\dfrac{g(e^{-2cx}-1)}{c}
Now the sign of \dfrac{g(e^{-2cx}-1)}{c} is determined by e^{-2cx}-1 which is not necessary positive definite.
In fact if we put c=1,x=1 we get e^{-2}-1<0 which means that p\in \mathbb{C}
But p=\dfrac{dx}{dt} which makes no sense at all. Did I do something wrong?
The sign of the drag force in the above equation is wrong.
By the way, I don't see why we have to use Lagrangian here, since Newtonian method is much more simple.
EDIT: Actually you may change either the sign of the drag force or the sign of the potential energy, but only one of them. Both yield the same correct equation.
I think you have a sign issue here. Shouldn't it be:
m\dfrac{d^2 x}{dt^2}=mg-k\left(\dfrac{dx}{dt}\right)^2
Mass*acceleration equals the sum of the forces. The net force is gravity minus drag.
Yes I see that now. Can you explain where I went wrong in my derivation of the friction.This is what I thought
F=-k\dot{x}^2 \hat{\textbf{v}}
\hat{\textbf{v}}=\dfrac{\textbf{v}}{||\textbf{v}||}=\dfrac{(\dot{x})}{\dot{x}}=(1)
Where the brackets denote a vector in the x direction.
Now obviously \hat{\textbf{v}}=(1) is wrong, because the particle accelerates in the negative direction, but why?
Edit
Never mind. I find out on my own.
There is nothing wrong with \vec{F}=-kv^2\hat{v}. But you must be careful when jotting down F = -kv^2 (*) (that means F<0). Since the ball is falling, the force must act upwards. So when you write (*), that means the positive direction of x-axis is downward.
Now in order that potential energy V = mgx, the x-axis must point upwards, which is inconsistent with (*) as explained above.
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
