Air Hockey Table Inclination Calculation
  • Thread starter Thread starter nateshoe
    Air Table
The problem involves calculating the inclination of an air hockey table based on the motion of a puck. The puck is given an initial velocity along the length of the table, and its drift to the side is observed, indicating that the table is not level.
  • Some participants discuss the dimensionality of the problem, suggesting it may be simpler than initially perceived. There are attempts to visualize the forces acting on the puck and derive equations for acceleration. Others express uncertainty about how to set up the problem.
Participants are exploring different interpretations of the problem, with some guidance provided on how to approach the calculations. One participant has indicated they have resolved their confusion.
There is mention of the problem being constrained to two dimensions due to the absence of friction, and the focus is on the effects of gravity on the puck's motion.
nateshoe
A physics student playing with an air hockey table (a frictionless surface) finds that if she gives the puck a velocity of 3.82 m/s along the length ( 1.65 m) of the table at one end, by the time it has reached the other end the puck has drifted a distance 2.47 cm to the right but still has a velocity component along the length of 3.82 m/s. She concludes correctly that the table is not level and correctly calculates its inclination from the above information.
I don't even know where to start! It has to be solved in three dimensions and I'm having trouble setting it up.
this problem could be a lot simpler than you first think. At first sight, admittedly, it looks like a 3d vector problem. However, given that there is no friction, and the only force affecting the motion is the weight, it is in fact a 2 - dimensional problem. The vertical plane (with weight "visible") is where the mechanics goes on, and the motion along the table is useful for one thing only - calculating the transit time. There is no force in this direction.
Try drawing a diagram representing the puck as a particle and the table as a line at an angle to the vertical. The only force acting is weight. Draw this force on. Now, try and derive an equation for the acceleration "sideways" across the table. Bearing in mind about what I said earlier about using the other direction to calculate the time, you should easily be able to just use kinematic equations of motion, and it's a fairly simple problem. Good luck
by the way, the answer I get for this problem is quite a small angle, which is probably intuitively what one would expect!
I got it figured out, thanks!
9K
