Air pressure and force of lift
The discussion centers on calculating lift using Bernoulli's principle, focusing on the relationship between pressure differences and wing surface area. The formula for lift is identified as force equals area multiplied by pressure. The user seeks clarification on using a pressure difference expressed as a percentage of atmospheric pressure, specifically asking if a 4% difference translates to a pressure value of 0.04 in the formula. This highlights a common confusion in applying percentage values to physical formulas. Understanding how to convert pressure differences into usable values is crucial for accurate lift calculations.
spidey64
I know about Bernoulli's principle and that a difference of pressure below and above a wing create lift, but I cannot find anywhere a formula or any information on how to find the amount of lift given the surface area of the wing and the difference in pressure as a percentage of atmospheric pressure...my book is not helpful at all.
I've found that force = area X pressure, which of course makes sense...but given that my problem gives me the difference of pressures below and above as 4% atmospheric pressure, is the pressure value in that formula .04?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
