Air resistance (pebble throwing)
jojoking
i have solved the question of a pebble thrown upwards without air resistance
speed 10m/s mass 0.02kg ma=w, w=-mg
man on cliff 50 feet high throws pebble upwards so it finishes in sea,
what height does it reach v=0 t = 10/g approx =1
since motion started at t =0 & duration of time 1s
x = 100/g - 100/2g is approx 5.1m so maximum height 55.1 m
BUT
i now need to find height with air resistance 0.008 v
any pointers to x value warmly recieved
cheersjk
Again, mass times acceleration equals force.
Without air resistance, the only force its weight: -mg so you have
m\frac{dv}{dt}= -mg
The easy solution to that is v= -gt+ C. Since the initial velocity is 10 m/s
v(t)= dx/dt= -gt+ 10. Integrate again to get x as a function of t. Solve v(t)= -gt+ 10 to find when it stops going up, put that value of t into the x fuction to find the highest point.
I said that to review what you must have done. Now, with air resistance, the force is -mg- 0.008v (negative because friction force always opposes v).
Your equation is
m\frac{dv}{dt}= -mg- 0.008v
You can rewrite that as
\frac{mdv}{mg+0.008v}= -dt[/itex]<br /> and integrate both sides to find v as a function of t. From there the rest of the problem is the same.
i understand your reasoning, thank you
cheers jk
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
