How Does a Solar-Powered Air Conditioner Work?
Solar-powered air conditioners typically rely on solar energy to operate, but they are not standalone units; they require a connection to a solar power system. Current technology suggests that while solar generators can power traditional air conditioning units, a self-contained solar air conditioner is not feasible due to high energy demands. Innovative concepts, such as using a Stirling engine with a buried fluid loop for cooling, have been proposed but remain theoretical. The discussion highlights a lack of significant breakthroughs in creating fully solar-powered air conditioning systems. Overall, while solar energy can assist in cooling, practical applications are still limited.
bags
hey frenz ,
Plz let me know about an Airconditioner working on solar energy.How does it work.Wheather any reaserch is going on this project?
Is any breakthrough has happened?Any help is welcome.
What do you mean an air-conditioner that runs on solar energy? Most electrical air conditioners are connected to some sort of power supply and yes, that power supply can be a solar generator but as far as i know, there's no such thing as a stand-alone air conditioner that runs on solar power. They require a LOT of power that solar energy cannot supply on a self-contained unit. You can have one that is powered by a solar grid that's attached to the air conditioner... but I just don't see anyone even wanting to make it into a self-contained unit.
Well if someone asked me to design one I would consider a sterling engine (solar powered though focusing by mirrors or whatever) running a pump that moves fluid around a closed loop. This loop would be buried in the ground where the temperature is a constant 50 some degrees F year round. Run this fluid through a heat exchanger and you have an air conditioner. A solar powered heat pump for heating in the winter seems kind of silly though so I doubt I would expand on this idea.
Solar powered fan, blowing across a block of ice! Air- conditioning!:biggrin:
I'm thinking "solar-powered umbrella"...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
