Aircraft landing impact & tires forces analysis
The discussion focuses on the analysis of forces during aircraft landing, particularly the dynamics of tire skidding and friction torque when the rear wheels touch the runway. It highlights the importance of understanding the vertical sink rate that the tires and hydraulics must manage before friction analysis can be effective. Previous experiments on the benefits of spinning up wheels before touchdown yielded no significant advantages, leading to the abandonment of such efforts. Estimating G loading during landings could provide some insights, but the value of these estimates is questioned. The complexity of analyzing these forces, especially for heavy aircraft, is acknowledged as a significant challenge.
aar2014
how is the smartest, can do the analysis?
Ok
when the Airplane touch the runway. the rear wheels touch first, in part of second, the rear tires skidding and then start to spin up. I need to analysis the forces to find:
friction torque, skidding, slip ratio,...
you can use any data or just find the correct formula... thanks for all
Surely the heart of the problem is that there is a vertical sink rate that the tires and hydraulics must absorb before any friction issues become amenable to analysis.
If memory serves, there have been experiments to measure the benefit from spinning up the wheels before touchdown. As no benefits were found, the effort was abandoned.
Consequently I doubt analysis of the forces has been achieved.
You could make an estimate based on the G loading on the landing gear for "normal" and "heavy" landings. Whether the estimate would be worth much is another question.
How to stop trainee pilots landing light aircraft with the wheel brakes on (easily done by accident, if the brakes are close to the rudder bar) is probably a more important questiion!
yes, we need the torque to know how much torque required to spin the wheels. however, it is for heavy airplane. but the analysis is very complicated
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
