Algebra (easy for you, difficult for me)
  • Thread starter Thread starter synthetic.
    Algebra
The discussion centers on two algebra problems needing solutions. For the first problem, participants suggest rearranging the equation t(t-x) = 3y(3y-x) to isolate x, ultimately arriving at x = (9y² - t²) / (3y - t), emphasizing the importance of not dividing by zero. The second problem involves solving (x+4)/x - 14/(2x-1) = 0, with participants suggesting methods like multiplying through by common denominators and using the quadratic formula to find solutions. The conversation highlights common struggles in algebra, particularly in rearranging and solving equations effectively. Participants offer various approaches and corrections to help clarify the algebraic processes involved.
synthetic.
I haven't done Maths for some time, and my Algebra needs some work.
Two questions in particular;
a) Rearrange for x in terms of y and t, to its simplest form.
t(t-x) = 3y(3y-x) [3y-t =/= 0]
b) Solve for x
a) I have taken a couple of different approaches, but here is one
t^2 - tx = 9y^2 - 3yx
3yx = 9y^2 - t^2 + tx
x = (9y^2 - t^2 + tx) / 3y
x = 3y - t^2 + tx
tx = t^2 + x - 3y
x = t + x/t - 3y/t
x - x/t = t - 3y/t
And when i try to take it any farther i end up going round in circles, or finding fanciful methods of ending up where i started.
b) Multiplying both Numerators by (x) and (2x-1), and cancelling, leaves
(x+4)(2x-1)=14x
2x^2 - x +8x - 4 = 14x
2x^2 - 7x = 4
x (2x-7) = 4
x = 4/(2x-7)
4/x - 2x = -7
Similarly, i can't see how to go any farther without going round in circles. Can i go to 2x^-1 - x = 7/2? Even then i wouldn't know where to go.
Thanks to anyone who offers help.
ok so let me try this
t^2-xt=9y^2-3yx
move x to one side
(t^2-9y^2)=xt-3yx)
factor out x
xt-3yx=x(t-3y)
so distribute it and solve for x
(t^2-9y^2)/(t-3y)
b) Solve for x
ok...
move and separate the two
(x+4)/x=14/(2x-1)
multiply them out
(2x-1)(x+4)=14x
2x^2+8x-x-4=14x
2x^2-7x-4=0
using FOIL
(2x+1)(x-4)=0
and so if you take each separate factor
x=-1/2 and 4, make sure however that they don't contradict the statement,(ie. in original solution, denominator =0) which it doesnt
b) Solve for x
x = 3y - t^2 + tx
tx = t^2 + x - 3y
x = t + x/t - 3y/t
x - x/t = t - 3y/t
You are almost there. Your objective is to get x by itself. Now you have x- xt. Well, that's equal to x(1- 1/t). x(1- 1/t)= t- 3y/t. You can get x by itself by dividing both sides by 1- 1/t. That will, however, give you a messy fraction on the right. Since I don't like fractions, I would suggest multiplying both sides of the equation by t first.
(x+4)(2x-1)=14x
2x^2 - 7x = 4
x (2x-7) = 4[/quote]
No point in factoring there. The only reason you might want to factor polynomials is because "if ab= 0 the either a= 0 or b= 0". You need to get "= 0" first. 2x^2- 7x- 4= 0. Now either factor if you can do so easily, or use the quadratic formula.
x = 4/(2x-7)
4/x - 2x = -7
b) Solve for x
a)
expanding out - t^{2}-tx=9y^{2}-3yx
moving all x terms to one side - 3yx-tx=9y^{2}-t^{2}
factoring the x terms out - x(3y-t)=9y^{2}-t^{2}
dividing both sides to make x the subject - x=\frac{9y^{2}-t^{2}}{3y-t}
note how the question stated that 3y-t\neq0, since in maths one cannot divide by 0, this is to help you. If the question never stated that, you would have to add it in yourself in your solution.
If you understand how to factorise with "the difference of 2 squares", then it should be noticeable that the answer can be simplified.
b)
Multiply by x(2x-1) - (x+4)(2x-1)-14x=0
expanding out and collecting like terms - 2x^{2}-7x-4=0
The solution can be factorised, but if you are unsure how to do this, you can use the quadratic formula to find the solutions:
For a quadratic polynomial ax^{2}+bx+c=0
The solutions to x can be found using x=\frac{-b\pm\sqrt{b^{2}-4ac}{2a}
Thanks to you all, much.
Where would one be without PF.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
