Algebraic solution of Trig equation.
  • Thread starter Thread starter synthetic.
    Trig
To solve the equation 5cosx - 2 = -0.72 for x in the range 0 ≤ x ≤ 2π, the derived equation is cosx = 0.256. The confusion arises regarding the expected output format, as the problem specifies radians but provides decimal answers. The discussion highlights that while some problems yield solutions in terms of π, others result in decimal values due to the nature of the trigonometric functions involved. Ultimately, the solutions for x are approximately 1.31 and 4.97 radians, which correspond to the first and fourth quadrants. Understanding the context of the trigonometric functions is essential for interpreting the results correctly.
synthetic.
The question as is written :
Solve for x
5cosx-2= -0.72 ( 0 \leq x \leq 2\Pi )
(The answer given is "1.31, 4.97".)
So, i done what seemed natural.
5cosx-2=-0.72
5cosx = 1.28
cosx = 1.28/5
cosx = 0.256
Firstly, I'm not even sure what unit my answer is supposed to be in. Since x is defined as Radians in the question, my answer of .256 = .256pi Radians (.256 of 180)?
Which should give solutions in the 1st & 4th quadrants.
All of the questions until (there are a bunch similar to this) these ones have been in the form of, for example, 4=5 - tan2x (x in radians), which, as there are no decimals in the solution work out easy (pi/8, 5pi/8).. . why, if x is defined in Radians in the question, are the answers in decimals? I don't understand the principle of this when decimals are involved for some reasons.
x=\cos^{-1}{\left(\frac{2-0.72}{5}\right)}
Should be in radians.
Find the values in the 1st and 4th quadrant.
Well if 5-tan2x=4 then that is the same as tan2x=1,right? and arctan(1)=pi/4
The only reason why are usually get your answers in terms of pi are most likely due to the fact that the questions you do end up with a trig function being equal to a standard number.
For example, sin3x=\frac{\sqrt{3}}{2} \Rightarrow 3x=sin^{-1}(\frac{\sqrt{3}}{2})
and sin^{-1}(\frac{\sqrt{3}}{2})=\frac{\pi}{3}
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
