Allowed and Forbidden Electron-Photon Reactions
  • Thread starter Thread starter Vrbic
    Reactions
The discussion centers on demonstrating that the conservation of 4-momentum prohibits the absorption of a photon by an electron, expressed as e + γ → e. Participants analyze this using spacetime diagrams and frame-independent calculations, emphasizing the importance of both momentum and energy conservation. A key point raised is that if an electron at rest absorbs a photon, it leads to a negative energy scenario, which is physically impossible. The conversation also notes that considering the time-reversed process of an electron emitting a photon further clarifies the impossibility of the initial reaction. Overall, the analysis confirms that such a photon-electron interaction cannot occur under the laws of physics.
Vrbic
Show, using spacetime diagrams and also using frame-independent calculations, that the law of conservation of 4-momentum forbids a photon to be absorbed by an electron, e + γ → e.
##\textbf{p}_{e1}+\textbf{p}_{\gamma}=\textbf{p}_{e2}## : ##(E_1,\vec{p_1})+(E_{\gamma},E_{\gamma}\vec{n})=(E,\vec{p_2})##,
where ##\textbf{p}## is 4-vector, ##\vec{p}## is ordinary 3-vector and ##\vec{n}## is unit vector in photon's direction.
##E=\sqrt{p^2+m^2}##
I take only 3-vecotrs and I (I hope I may) suppose ##\vec{p_1}=0## i.e. is in rest.
##\vec{0}+E_{\gamma}\vec{n}=p_2\vec{n}=>\sqrt{E^2-m^2}=E_{\gamma}##
First time I put there ##E=\frac{1}{2}mv^2## but I feel it is not good probably. Is my beginning right? What should I use or think about?
You used conservation of momentum so far.
What about conservation of energy?
The problem is easier in the reference frame of the electron in the final state.
Ok, ##(\gamma m, \vec{p}) + (E_{\gamma},E_{\gamma}\vec{n})=(m,\vec{0})##. Right? From energy part than we have ##E_{\gamma}=m(1-\frac{1}{\sqrt{1-v^2}})<0##. And it is this problem, negative photon's energy?
Right.
Time-reversed, the process would be an electron at rest emitting a photon and gaining kinetic energy at the same time. Written like that, it should be clear that it cannot happen.
Likes Vrbic
mfb said:
Right.
Thank you.
