How Does Alternating Current Work?
Alternating current (AC) periodically changes direction, which raises questions about how charge circulates in a circuit. An analogy using beads on a wire illustrates that while the beads move back and forth, they still create a flow that can be measured. Direct current (DC), in contrast, involves a unidirectional flow of electric charge, but electrons do not travel from the power source to the device in a linear fashion. Instead, the current represents a directive force that prompts free electrons to move in the designated direction. Understanding these concepts clarifies the behavior of AC and DC in electrical systems.
ronaldoshaky
Hello
I read on Wikipedia that alternating current periodically changes direction. So if it keeps going backwards and then forwards how does the charge get around the circuit?
Thanks
Think of beads on a wire, filling the wire like a pearl necklace. Suppose the wire forms a loop a meter in diameter.
Push a bead forward 3 cm. Pull it back 3 cm. Repeat. Your finger is the motive force. Have someone else watch, somewhere on the far side of the loop: he is the amp meter. Will he report beads moving? Yes, back and forth, at whatever velocity.
--John
I would like to add something to your example JD, something that maybe even the initial poster knows already but I find that I should point out.
Direct current is unidirectional move of electric charge, but that doesn't mean that electrons travel from the switch to the electric device in order to power it. I think of the current as the "order" that is given to the wire by the generator for all free electrons along the wire to start moving, to one direction when it comes to direct current and back-forth when it comes to alternating current.
I hope I've helped.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
