Altitude of a Rocket Launched into Space
A 4.60 kg rocket is launched upward from Earth at a speed of 9.00 km/s. The relevant equation used to determine the altitude is v = √(2GM/r), where G is the gravitational constant. The calculation yielded a radius of 6.8 x 10^-14 m, indicating the height needed to escape Earth's gravitational pull. The mass of the rocket is irrelevant in this context, as all objects in freefall accelerate uniformly. This discussion highlights the application of escape velocity in determining the altitude necessary for a rocket to leave Earth's gravitational influence.
tesla93
The Problem:
A 4.60 kg rocket is launched directly upward from Earth at 9.00 km/s
What altitude above the Earth's surface does the rocket reach?
Relevant Equations:
v = √ (2GM/r)
The Attempt:
m = 4.60 kg
v = 9km/s = 9000m/s
G = 6.67 x 10^-11
9000^2 = 2(6.67^-11)(4.60)/r
r = 6.8 x 10-14m
I used that formula because it is for escape speed, which I think applies to this question, as it needs to be a certain height above the Earth to escape the pull and stay in orbit.
"M" is the mass of the Earth, not of the rocket. The mass of the rocket doesn't matter because in freefall, all objects accelerate at the same rate, regardless of mass.
Oh alright that makes sense. Thank you!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
