Aluminum vs Steel: Is Strength Claim True?
  • Thread starter Thread starter smartin1
    Aluminum Steel
The discussion centers on the comparison of load-bearing capacities between aluminum and steel I beams. It highlights that claims of aluminum I beams surpassing steel in strength are not necessarily false advertising; rather, they depend on specific factors such as the alloy composition, heat treatment processes (like annealing or cold working), and the geometry of the beams. Examples of high-strength aluminum alloys are provided to illustrate this point. The conversation emphasizes that both aluminum and steel can be engineered for high strength, making direct comparisons complex and reliant on individual material properties.
smartin1
I'm a little confused and i would appreciate if someone could enlighten me on how there are some claims of certain manufacturers that the strength or load bearing capacities of aluminum I beams can surpass steel I beams? is that false advertising or can that statement ring true?
Please help.
Could well be true; it all depends on the alloys and dimensions of the I beam itself.
can you provide any examples to clarify?
Example of high strength Al alloys - http://www.vtol.org/f65_bestPapers/structuresAndMaterials.pdf
It depends on the alloy, composition, heat treatment (annealed vs cold worked, stress-relieved), and component geometry.
One can find annealed steels or cold-worked steels, as well as high strength steels.
