Am I doing this torque on dipole problem right?
  • Thread starter Thread starter schattenjaeger
    Dipole Torque
schattenjaeger
You've got a circular loop with a steady current I and radius 'a' a distance r from a square current carrying loop with sides of 'b' and current I, r >>> a or b(and they're arranged in such a way as you can think of the circular loop's dipole as pointing up, and the square loop point right)
What's the torque ON the square loop caused by the circular loop, and the square loop's final orientation assuming it's free to move
A couple of ways to get B, I figure the curl of A, and I have A for a dipole, which will I use with the circular loop
Then the torque on a dipole in a B field is B x m, where m is the dipole, in this case the square loop's dipole
Err, I guess that was my attempt pretty much, I just need to make sure that's the right way to do it
Just a thought here, buuuut isn't the B field of a circular current just a straight line going through its center(orientated with the right hand rule)? So...would there even be a torque on the square loop?
Edit: No wait that's totally wrong
Think I got it, I'll just put in my own work for shiggles
Well no, I don't know Latex worth a damn, suffice it to say I used the formula for B for a magnetic dipole sensed by another dipole, with the angle between them being pi/2, and ultimately I got
N=-I^2ua^2b^2/(4r^3) in the x-hat direction, which I believe means it'd rotate until it was antiparallel with the circular loop's moment, then theta =0, and no more torque(though I guess technically it'd swing past but blah blah ultimately they're anti-aligned?)
The magnetic dipole moment of each loop is just mu=IXarea/c (in gaussian units). Then, the torque is calculated just as if they were electric dipoles.
torque=muXB, where B is torque due to the other dipole.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
