Am I integrating this right: (x^2 + 3x + 11)/(x+2)^4 ?
  • Thread starter Lo.Lee.Ta.
  • Tags
    Integrating
In summary, the conversation is about integrating the function (x^2+3x+11)/(x+2)^4 using partial fractions and u-substitution. The steps taken are to first set up the partial fractions and find the values of A, B, C, and D, then use u-substitution to simplify the integral. The final result is checked by taking the derivative.
Lo.Lee.Ta.
217
1. ∫(x2 + 3x + 4)/(x+2)4dx
2. With these sorts of problems, I think about integration by partial fractions.
So in this case, the denominator factors are all the same, so I have to make each one with different exponents.
I wrote:
A/(x + 2) + B/(x + 2)2 + C/(x + 2)3 + D/(x + 2)4
I multiplied to get common denominators:
A(x + 2)3 + B(x + 2)2 + C(x + 2) + D = x2 + 3x + 11
Now I need to figure out what A, B, C, and D equal.
When I substitute x=-2, D=9
A(x + 2)3 + B(x + 2)2 + C(x + 2) + 9 = x3 + 3x + 11
I think I am supposed to take the derivative now to figure out the other values.
2x + 3 = 3A(x + 2)2 + 2B(x + 2) + C
When I substitute x=-2, C= -1
Now, am I able to take the derivative again?
That's what I did next:
Substituting x=-2,
2 = 6A(x + 2) + 2B
B=1
If x=1,
2 = 6A(x + 2) + 2(1)
A=0
...Am I even doing this right? :/
I don't want to go on if I'm not even doing this part right!
Thank you very much! :D
Substituting x=-2,
2 = 6A(x + 2) + 2B
B=1
If x=1,
A=0
If your original integrand was (x^2+3x+11)/(x+2)^4 (you probably have a typo), then, yes, you got the partial fractions right.
Oh, yes, was a typo! Thanks for letting me know it's right so far! :)
Alright, now I have:
∫(0/x+2) + (1/(x+2)2) - 1/(x+2)3 + 9/(x+2)4dx
U-substitution!
u= x+2
du=dx
∫u-2 - u-3 + 9u-4du
= -u-1 - u-2/-2 + 9u-3/-3
= -1/(x+2) + 1/(2(x+2)2) - 2/(x+2)-3
...Is this right?
Thanks so much! :)
∫(0/(x+2)) + (1/(x+2)2) - 1/(x+2)3 + 9/(x+2)4dx
U-substitution!
u= x+2
du=dx
∫u-2 - u-3 + 9u-4du
...Is this right?
Thanks so much! :)
You can check by taking the derivative of the result.
By the way: This problem can be done more easily by using u-substitution at the outset, with u = x+2 .
What is integration?
Integration is a mathematical process that involves finding the area under a curve. It is the reverse operation of differentiation and is used to solve problems in calculus and other areas of mathematics.
What does it mean to integrate an expression?
Integrating an expression means finding the function whose derivative is equal to the given expression. It involves finding a function that, when differentiated, will result in the original expression.
How do you integrate a rational expression?
To integrate a rational expression, you can use the method of partial fractions or the substitution method. In the case of (x^2 + 3x + 11)/(x+2)^4, the substitution method would be the most efficient approach.
What are the steps to integrate (x^2 + 3x + 11)/(x+2)^4 ?
The steps to integrate (x^2 + 3x + 11)/(x+2)^4 are as follows:1. Use the substitution method by letting u = x+2.2. Rewrite the expression in terms of u, which would be (u^2 - 4)/(u^4).3. Use long division to simplify the expression to 1/u^2 - 4/u^4.4. Integrate each term separately, which would result in -1/u - 1/(3u^3) + C.5. Substitute back in the original variable, x, to get the final answer of (-1/(x+2)) - (1/(3(x+2)^3)) + C.
How do you know if you have integrated correctly?
You can check if you have integrated correctly by differentiating your answer. If the derivative of your answer is equal to the original expression, then you have integrated correctly. You can also verify your answer by using an online integration calculator or by consulting a mathematics textbook or teacher.
