Amount of power as a person climbs stairs
  • Thread starter Thread starter SnitchSeekaHarry
    Power
To estimate the power generated by a person climbing stairs, one must consider the energy expended over time. Power is defined as energy per unit time, so calculating the work done against gravity provides a basis for estimation. While the exact energy from metabolic processes is difficult to quantify, an approximation can be made using the change in gravitational potential energy as the person ascends. This approach assumes a constant climbing speed, simplifying the calculations. Understanding these principles allows for a reasonable estimation of the power output during stair climbing.
SnitchSeekaHarry
Can anyone give me an idea on how to estimate the amoung of power that a normal person will general as he climbs stairs?
Power is energy in unit time.Estimate the time in which energy is being expended and that amount of energy.
Daniel.
But how about energy?
How can I estimate energy?
Unfortunately,u can't estimate the real energy involved,namely the energy released from the chemical reactions that take place in your body while u're climbing that ladder.But you can approximate (i don't know how accurate,though) that with the work done by your body against gravity (equivalently,the variation in gravitational potential energy of your body),assuming you climb at constant speed wrt the ground...
Daniel.
