breeno
- 9
"The graph shows the characteristics of four different voltage amplifiers (A-D). The input voltage to these amplifiers is limited to between + & - 600mV.
If you cannot see it properly it also says "If the input voltage is as shown (see bottom graph), sketch the output voltage for amplifiers B and D."
Voltage gain = change in output voltage divided by change in input voltage.
To use B as an example. I've tried finding the voltage gain (rise over run or the formula above) to get 8.33. I then use that as the voltage gain and rearrange the above formula but alas it didn't work. If it helps, the book shows (for B) a peak voltage of 1.8v and a trough of 1.8v.
Any help would be appreciated.
