An acceleration/distance/velocity question.
  • Thread starter Thread starter username111
The problem involves a car accelerating at 6.0 m/s² and a truck moving at a constant speed of 21 m/s. To determine how far the car travels before overtaking the truck, two distance equations must be set equal: one for the car and one for the truck. For the second part, the car's final velocity when it overtakes the truck can be calculated using the distance found in the first part. The key is to establish the relationship between the two vehicles' distances and apply the appropriate kinematic equations. This approach will yield both the distance and the speed of the car at the point of overtaking.
username111
As a traffic light turns green, a waiting car starts with a constant acceleration of 6.0 m/s^2. At the instant the car begins to accelerate, a truck with a constant velocity of 21 m/s passes in the next lane.
A)How far will the car travel before it overtakes the truck?
B)How fast will the car be traveling when it overtakes the truck?
i have all of the following formulas:
vf = vi+at
d = (vf+vi)/2 x t
d = (vi)(t) + 1/2(a)(t)^2
vf^2 = vi^2 + 2(a)(d)
i'm thinking i have to set a distance equation equal to the other one for A. I'm just not sure how to start the problem or anything. and for B, do i use what i'll get for distance and plug it into another equation?
(a) Write two separate distance equations, one for the car and one for the truck. What can you say about these two distances when the car reaches the truck?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
