An attempt frequency for a harmonic oscillator?
Duave
An "attempt frequency" for a harmonic oscillator?
What is the "attempt frequency" for a harmonic oscillator with bound potential as the particle goes from x = -c to x = +c? What is the rate of its movement from -c to +c?
v =\frac{1}{2π}\sqrt{\frac{k}{m}}
ω=\sqrt{\frac{k}{m}}
1. x(t) = Acos(ωt)
2. \frac{d x(t)}{dt} = -Aωsin(ωt)
3. v(t) = \frac{d x(t)}{dt}
4. v(t) = -Aωsin(ωt)
5. -\frac{v(t)}{Asin(ωt)} = ω
6. ω = -\frac{v(t)}{Asin(ωt)}
4. Conclusion
Is the expression (equation) below the proper equation to use to determine the "attempt frequency" for a harmonic oscillator with bound potential as the particle makes its way between x = -c and x = +c?
ω = -\frac{v(t)}{Asin(ωt)}?
Define "attempt frequency"?
Define "rate of movement"?
State these definitions in words and compare with what you've done.
Likes 1 person
Thank you very much Simon.
The only problem is I've looked all around the universe and could barely even find a source that said even literally said "attempt frequency". I don't know what the definition is.
And, "rate of movement" to me is defined by some measurement over time, but, I still can't put 2 and 2 together, just because it's definition is so straight forward.
I wrote all the things in my question, because I needed someone to correct it for me. I'm have not found anything that could confirm its "correctness".
Thanks
If you don't know what those two terms mean, then you cannot do the problem.
Googling "attempt frequency" gets lots of examples of it's use.
Googling the "definition attempt frequency" suggests:
"attempt frequency" is the rate that a bound particle "attempts" to escape the potential.
http://encyclopedia2.thefreedictionary.com/attempt+frequency
... so how many opportunities per second does the particle have to escape?
"rate of movement" could refer to dx/dt - the velocity ... but why not just say "velocity"?
It could also refer to the rate that particles escape the well.
Both of these are used quite a lot.
What does the value of c signify? Is it the classical limits for a particle with a particular energy or some arbitrary point inside those limits?
If this is part of coursework then you should have had these terms used as part of the course somewhere.
The context will help - like: is this part of the course on SHM in general or about nuclear physics or what?
Since you have not found any such reference - you should go ask the person who set the problem.
Likes 1 person
Simon,
-c and +c are the bounds. Okay look at this:
1. x(t) = Acos(ωt)
2. \frac{d x(t)}{dt} = -Asin(ωt)
3. \frac{d x(t)}{dt} = v(t)
4. \frac{d x(t)}{dt} = velocity
5. v(t) = -Asin(ωt)
How does step five look? I even took the derivative of the position, which would be the velocity.
Thanks again
You have decided to interpret "rate of movement" to mean "velocity"?
Step 2 is incorrect. Hint: chain rule.
You could have checked this yourself by checking that the units on the RHS of equ5 match the units on the LHS.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
