Efficient AC: How Does It Reduce Compressor Work Load?
  • Thread starter Thread starter PatPwnt
    Ac
The discussion centers on a patent that claims to reduce the workload on a car air conditioner's compressor by super-heating gas with exhaust heat after it exits the compressor. However, participants argue that this method actually increases the compressor's workload, as raising the gas pressure post-compressor necessitates a higher discharge pressure. Additionally, the added heat must be dissipated by the condenser, potentially leading to poor AC performance. The consensus is that the patent's approach contradicts basic thermodynamic principles. Overall, the proposed method is viewed as ineffective and likely detrimental to air conditioning efficiency.
PatPwnt
The patent in the link explains that it reduces the work load on the compressor in a car air conditioner by using heat from the exhaust to super-heat the gas directly after it exits the compressor. Other than that it seems to be a normal air conditioner. I am having trouble understanding how this reduces the load on the compressor. Wouldn't the increased pressure of the hot gas work against the pistons in the compressor? How does it work?
http://www.freepatentsonline.com/7412843.pdf
Prime example of what little checking the patent office does.
This does increase work on the compressor. You cannot increase the pressure of the gas after the compressor without increasing the discharge pressure of the compressor. Also added heat must then be removed from the condenser. So all it would do is make your AC work very poorly.
chayced is right. There's no increase in pressure by heating the working fluid after it leaves the compressor. That seems to be what they're patenting - it's even written into claim #1.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
