An ellipse fitting into a notch problem.
  • Thread starter Thread starter polishdude20
    Ellipse Fitting
An elliptical disk is designed to fit into a notch that is 180 mm wide, with the disk's major axis measuring 280 mm and minor axis 40 mm. The problem involves calculating the necessary depth of the notch for the disk to touch its back edge. The user correctly identifies the semi-major and semi-minor axes as 140 mm and 20 mm, respectively, and attempts to apply the ellipse equation to find the depth. However, they encounter an issue resulting in a negative value before taking the square root, indicating a potential error in their calculations. Clarification on the diagram and arithmetic is suggested to resolve the misunderstanding.
polishdude20
I did this one before a few weeks ago but now I can't seem to get the right answer:
An elliptical disk is to fit snuggly and squarely into a notch cut into a rectangular plate. The notch is 180 mm wide. If the disk's major axis is 280 mm long and is parallel to the long edge of the notch, and the disk's minor axis is 40 mm wide. How deep does the notch need to be for the right edge of the disk to just touch the back of the notch?
(x^2)/(a^2) + (y^2)/(b^2) = 1
So I know that the "A" value is half of the major axis of the ellipse so it's 140mm, the "B" value is half of the minor axis so it's 20mm. The notch is 180mm wide so the x value for the edge of the notch which touches the ellipse is half of that which is 90mm. So I lug the numbers into the ellipse equation to solve for the Y value. I square the 140 and the 20 and the 90 in my calculations according to the formula and I get -12.8 so I thought that that would be the distance from the centre not from the bottom so I subtracted 12.8 from 20 which gave me 7.1. The answer is wrong.
Anyone have any ideas?
You get -12.8 before you take the square root to give y? Then there is probably something amiss right there. :smile: You explained what you were doing, and it seems right, so you'd better recheck. Post the arithmetic expression if you can't see your mistake.
Take a look at the diagram you drew, it will show exactly what y is. (You did draw a neat, large diagram, didn't you? With the ellipse centred at (0,0)? )
What is the correct answer, were you told?
