An ideal gas going through a cycle
The discussion revolves around a homework problem involving an ideal gas undergoing a cycle, with key equations provided, including the internal energy change and work done. The original poster, Ethan, expresses confusion over not matching the expected answer despite his calculations. A peer reviews Ethan's work and confirms that it appears correct. This suggests a potential discrepancy in the provided answer key rather than in Ethan's understanding or calculations. Clarification on the problem's expected outcomes may be necessary for resolution.
Ethan Godden
The problem is attached
ΔEint=Q+W
W=-PΔV
Attempted solution is in the attachment. The problem is I am not getting the same answer as the supposed correct answer.
Thank You,
Ethan
Ethan,
I checked your work and it all looks very good to me. I think your answer is correct!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
