Does a Ball Move Up or Down an Inclined Plane?
  • Thread starter Thread starter alwysnforevr002
    Inclined
The discussion centers on the motion of a ball on an inclined plane and the confusion regarding whether the ball moves up or down the incline. Participants clarify that if the ball starts at the top with an initial velocity, none of the specified quantities (initial position, final position, initial velocity, time) would be zero. It is suggested that the only time a quantity might be zero is when the ball's velocity slows to zero due to gravity. The conversation emphasizes the importance of understanding the problem statement and encourages seeking clarification from the professor. Ultimately, the consensus is that if the ball starts at rest on the inclined plane, initial velocity could be considered zero.
alwysnforevr002
Is the motion of a ball on an inclined plane mean the ball is going up the inclined plane or down the inclined plane?
The question goes as follows
The motion of a ball on an inclined plane is described by the equation . Which of the following quantities must have a value of zero?
xi
xf
vi
tf
Okay let me start over. This question is confuzing me.
If i can figure out what it means than i already know the answer. I am simply looking for a further explanation. Basically the question is
The motion of a ball on an inclined plane is described by the equation DeltaX = 1/2(acceleration(delta t)(squared))
xi
xf
vi
tf
NOW, my problem is that i don't know if the "inclined plane" is a plane starting from the top and then going down or starting from the bottom and going up.
I hope that is bit more clear. i apologize for the mess
The question is poorly presented to you, if that is the exact wording. Start the ball at the top of the inclined plane with some initial velocity, then nothing is zero. Ask you professor for a better problem statement. But be polite when you ask, unless you are already an A student aceing the class. Then poke some fun at him/her. :rolleyes:
xi
xf
vi
tf
And even if the ball is started up the inclined plane with some initial velocity, none of the quantities above would be zero. The only zero would come from when the ball's velocity slowed to zero and reversed itself due to gravity (easiest calc is PE(zero velocity) = KE(initial)).
Thank you. I will make sure to look that up. For now I have to pick the best answer and i think that would be initial velocity.
Like if it starts at rest on an inclined plane? Hmmm, that would seem to work. I didn't think of that.
