Are Moments Treated Differently than Forces in Beam Analysis?
  • Thread starter Thread starter aerograce
    Beam Structure
In beam analysis, externally applied moments can be summed to write equilibrium equations, as they behave like vectors, requiring attention to their point of application and direction. Moments can be treated as couples, allowing them to be combined even if applied at different points along the beam, as long as they act about the same axis. This property of moments, known as 'free vectors,' means they can translate without affecting the equilibrium of the beam, unlike forces. The discussion highlights the importance of understanding how moments interact in structural analysis, emphasizing that they do not influence the net force on the system when treated correctly. This concept is crucial for accurate beam analysis in mechanics and statics.
aerograce
I am always wondering, when we are analysing beam structure where many externally applied moments are added on, why we can sum up all the externally applied moments and write equilibrium equations according to that. Because these moments are actually along different axes. Is it because in analysing process, we treat all moments as couples? If that is the case, then in real life, is our analysing method inaccurate?
Well, moments have qualities of a vector like forces do. When you say, '... sum up all the externally applied moments ...', you must pay attention to their point of application and their direction. You don't just add up their magnitudes.
Its better to explain my point with one typical example in analysing a beam. You can view the attached file.
In the equation Mc(left)=0, it actually sums up the moments though they are along different axis.
I don't see your confusion. The reacting moment Ma and the applied couple at B are both acting about an axis coming out of the paper, even though they are applied at different points along the beam. Therefore, they can be combined by adding their magnitudes.
But their axes are actually not the same right? They are just parallel to each other. And also, why the moments applied won't affect the force equilibrium equations? Because if we don't assume moments as a couple, they will affect the net force on the system
I think the point you are missing about moments is that, unlike forces, they can translate without affecting the equilibrium of the beam. Moments, or couples, are known as 'free vectors' because of this property.
http://en.wikipedia.org/wiki/Couple_(mechanics)
This is a subtle, but important, characteristic which should be covered in any intro. mechanics or statics course.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
