Analysis (left and right-hand limits, monotonicity)
  • Thread starter Thread starter raphile
    Analysis Limits
raphile
Assume that f is a monotone increasing function defined on \mathbb{R} and that for some x_0\in \mathbb{R} the left and right limit coincide. Can you prove that f is continuous at x_0? Either give a complete proof or a counterexample.
I believe the function should be continuous at x_0\text{ } (otherwise, my whole answer is incorrect!). This is the proof I've come up with:
Given that the left and right limits coincide at x_0, call this limit L. Then we know (by definitions of left and right limits):
\forall \epsilon>0 \text{ }\exists \delta_1>0: \forall x\in \mathbb{R}\text{ with } -\delta_1<x-x_0<0\text{ we have }|f(x)-L|<\epsilon
\forall \epsilon>0 \text{ }\exists \delta_2>0: \forall x\in \mathbb{R}\text{ with } 0<x-x_0<\delta_2\text{ we have }|f(x)-L|<\epsilon
Suppose (for a contradiction) that the function is not continuous at x_0. Then we can say that |f(x_0)-L|=\tau>0, where \tau is some positive number. If f(x_0)>L then we have f(x_0)-L=\tau, and if f(x_0)<L then we have L-f(x_0)=\tau.
In the case where f(x_0)-L=\tau, take \epsilon=\tau\text{ } in the right-hand limit definition. Then we can say that for x\in (x_0,x_0+\delta_2) (in particular, for x=x_0+\delta_2/2) we have |f(x)-L|<\tau and hence f(x_0+\delta_2/2)<L+\tau. This means we have f(x_0)=L+\tau but f(x_0+\delta_2/2)<L+\tau, which contradicts the statement that f is monotonically increasing.
In the case where L-f(x_0)=\tau, take \epsilon=\tau\text{ } in the left-hand limit definition. Then we can say that for x\in (x_0-\delta_1,0) (in particular, for x=x_0-\delta_1/2) we have |f(x)-L|<\tau and hence f(x_0-\delta_1/2)>L-\tau. This means we have f(x_0)=L-\tau but f(x_0-\delta_1/2)>L-\tau, which contradicts the statement that f is monotonically increasing.
I'd really like someone to check whether this proof makes sense or possibly if there is a simpler way to do it, or even if I have the wrong answer to start with. Thanks!
Yes, this works. Sure, you could shorten the second part if you like. For instance you can use that by monotony f(x0) is stuck between two converging sequences with the same limit point, i.e.
f(x_0-1/n) \leq f(x_0) \leq f(x_0+1/n) for all n
\Rightarrow \lim_{n \in \mathbb N} f(x_0-1/n) \leq f(x_0) \leq \lim_{n \in \mathbb N} f(x_0+1/n)
\Rightarrow L \leq f(x_0) \leq L \Rightarrow f(x_0) = L
but yours is fine, too.
Also, depending on your definition of continuity (epsilon-delta-criterion?), you might want to point out how all of this fits together in proving the continuity of f.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
