Analytical bending of a deformed beam
The discussion revolves around deriving an analytical solution for the deformation of a beam subjected to moments C_1 and C_2, using the Bernoulli-Euler equation. The user seeks to apply displacement data from a deformed beam to create a new displacement profile, aiming for better alignment with their finite element analysis (FEA) model results. They currently add heat-induced displacement to bending displacement from their analytical solution, but this does not perfectly match the FEA outcomes. A suggestion to explore the virtual work/flexibility method for calculating deformation was made, acknowledging the challenge of adapting it to the unique profile of the deformed beam. The user expresses interest in improving accuracy in their modeling approach.
saybrook1
Hi guys; I have an analytical solution for the deformation of a beam due to a couple with moments C_1 and C_2 with boundary conditions y=0 and x=±(L/2) where L≡length of the beam. The derivation from the Bernoulli-Euler equation is below:
\begin{align*}
y''=\frac{\epsilon}{2}(C_1+C_2)-\frac{\epsilon}{L}(C_1-C_2)x
\end{align*}
Where ε = 1/E*I, I=Moment of inertia, E=Young's Modulus and L= beam length.
\begin{align}
y'=\frac{\epsilon}{2}(C_1+C_2)x-\frac{\epsilon}{2L}(C_1-C_2)x^2+C_3\\
y=\frac{\epsilon}{2}(C_1+C_2)\frac{x^2}{2}-\frac{\epsilon}{2L}(C_1-C_2)\frac{x^3}{3}+C_3x+C_4
\end{align}
For y=0 at x=-L/2;
\begin{align}
0=\frac{\epsilon}{4}(C_1+C_2)(\frac{-L}{2})^2-\frac{\epsilon}{6L}(C_1-C_2)(\frac{-L}{2})^3+C_3(\frac{-L}{2})+C_4\\
C_3=-\frac{\epsilon}{4}(C_1+C_2)(\frac{-L}{2})+\frac{\epsilon}{6L}(C_1-C_2)(\frac{-L}{2})^2+\frac{2C_4}{L}
\end{align}
For y=0 at x=L/2;
\begin{align}
0=\frac{\epsilon}{4}(C_1+C_2)(\frac{L}{2})^2-\frac{\epsilon}{6L}(C_1-C_2)(\frac{L}{2})^3+C_3(\frac{L}{2})+C_4
\end{align}
Plugging in equation (4) yields:
\begin{align}
C_4=-\frac{\epsilon L^2}{16}(C_1+C_2)
\end{align}
And plugging (6) back into (4) yields:
\begin{align}
C_3=\frac{\epsilon L}{24}(C_1-C_2)
\end{align}
With both integration constants determined, we arrive at our expression for vertical displacement:
\begin{align}
y=\frac{\epsilon}{4}(C_1+C_2)(x^2-\frac{L^2}{4})+\frac{\epsilon}{6}(C_1-C_2)(\frac{Lx}{4}-\frac{x^3}{L})
\end{align}This expression let's me come up with the displacement for an undeformed beam given certain values of C_1 and C_2. I was hoping that someone may be able to help me figure out a way in which I could take the displacement data(set of y-values) of a deformed beam and apply certain values of C_1 and C_2 in order to create a new displacement profile(new y-values). Any help or a point in the right direction would be greatly appreciated. Thanks and please let me know if you need any more information.
I'm still trying to fathom what you were asking about in your previous thread .
Why don't you just tell us in simple words and pictures what you are trying to do overall in this project ?
Okay, I'll try my best - I've got an FEA model where I apply a heat load to a beam and simulate the thermal expansion. After that, I apply a couple and bend the beam back in another step of the simulation. Often times I will plot the displacement of the top center line of the beam after heat deformation and after subsequent bending.
Right now, I can get the model to agree pretty well with an analytical solution - Ideally, I would like to be able to take this top center line of displacement data after heat deformation - and then use that data to analytically apply the couple(with moments C_1 and C_2) and then match this precisely with my FEA models.
Right now - I add the heat displacement data to the "bending" displacement values that I get from the above equation. This matches decently with the FEA but not perfectly because the above equation is bending an undeformed beam whereas the model takes the deformed beam and then bends it.
Please let me know if you have any more questions and thanks for the follow-up.
In an old paper, I used the virtual work/flexibility method to calculate the deformation and forces (Eqs. (15)-(32)) in statically indeterminate offset beams undergoing thermal expansion under a constraint. I haven't used the method since then, but it seemed powerful and might be of interest. It seems like the main challenge would be in adapting to the unique curved profile of your deformed beam.
That would absolutely be the main challenge - I have been scanning for papers like this; Thank you very much! - I'll let you know what happens; as it stands, the method I'm using now is functional but I would definitely like to add this extra degree of accuracy.
Ok . That is a lot clearer now .
This plot from your earlier post is representative of the magnitude of deflections that you are getting ? If so the centre point deflection is only about 0.3% of the beam length ?
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
