Analytical expression for electro-field around rectangle waveguide?
The discussion focuses on determining the electro-field around a rectangular waveguide, specifically in the corner regions where the mode is near cutoff. The waveguide has a higher refractive index (n1) than the surrounding cladding (n2), and the field expressions in regions II, III, IV, and V can be derived using the EIM or perturbation methods. However, the challenge lies in obtaining an analytical expression for the corner regions, as traditional methods often neglect these areas due to approximations. The coupling of x and y dependent solutions complicates the analysis when the mode is near cutoff, necessitating a comprehensive understanding of the electric field distribution. The inquiry seeks insights into accurately modeling the electro-field in these critical corner regions.
Cao Yu
i am now trying to figure out the electro-field around a rectangle waveguide. the refractive index of the waveguide is n1, which is larger than that of the cladding, namely n2, outside. we may regard the waveguide embeded in the cladding material.
as following shown, the waveguide crossection is the region I. It is surrounded by region II, III, IV, V and four corner regions.
i i
i III i
i i
i i
V i I i IV
i i
i i
i II i
i i
it is easy to get the electrical field expression in II, III, IV and V, by using EIM or purtabation method. Now my question is how to get the analytical expression in the four corner region, when the mode in the waveguide is near cutoff?
when the mode is far from cutoff, we will separate the mode into uncoupled X(x) and Y(y) solutions. in this way, we can tract the results for Ex and Ey separately. but if the mode is near cutoff, the x and y dependent solutions will be strongly coupled through the boundary conditions in the corner regions.
people normally neglect the field in the corner regions as their approximation. but the case i am studying now can not take this approximation. so i need to know all the electrical field distributuion around the waveguide.
anyboday has good idea? thanks a lot.
oh, the picture gets into a mass. hope someboday can understand it.
III and II are the regions just above and below the waveguide core, which is noted as I.
IV and V are the regions on the right and left of the core I.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
