Analytical mechanics: 2D isotropic harmonic oscillator
swindhspectrum
I'm stuck on this problem:
The initial conditions for a two-dimensional isotropic oscillator are as follows: t=0, x=A, y=4A, v=0i +3wAj (vector) where w is the angular frequency. Find x and y as functions of t.
Where do I even begin with this problem. I take it A = constant. Can anyone make this less intimadating?
thanks.
By isotropic I assume you mean the force depends only on the distance from the origin, ie, F=kr, directed towards the origin.
You probably want to start by considering the constants of motion. You know U=1/2kr^2, and that the total energy E=U+KE is conserved. Also, since the system has rotational symmetry, angular momentum is conserved, ie, r X v (the cross product of the position and velocity vectors) is a constant, equal to its initial value for all time. With a little work, and using polar coordinates, you can use these equations to turn the problem into an ordinary differential equation involving r.
EDIT: Actually, I've gone through the work, and that DE is a pain to solve. It's not impossible, but there's probably an easier way. If I think of one I'll let you know.
Right, so you might want to try the above approach, as it's similar to the methods you'll need to use on more difficult problems. But in this case, you can just separate the x and y equations of motion:
m\frac{d^2 \vec r}{dt^2} = -k \vec r
this gives:
\frac{d^2 x}{dt^2} = -k x
and
\frac{d^2 y}{dt^2} = -k y
These can be solved seperately. But note again that this method is not very general, and in most problems you'll need to do something like what I suggested in the last post.
thanks, ill try this out
i don't know if you (statusX) tried to solve these...
i am getting an imaginary answer for x (x=iwt). i haven't solved for y(t) yet. Isn't the imaginary answer somehow equivalent to a trig function? Does anyone know?
thanks
The solution to both equations will involve sines and cosines. Have you solved these types of equations before? I assume you meant to say you got something like x=e^iwt, which can be converted to sines and cosines using the http://mathworld.wolfram.com/EulerFormula.html" . You are solving a 2nd order ODE, so you should get two constants, which can be solved for by plugging in values for x and dx/dt at t=0.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
