Analytical solution for thermal stresses in a rectangular plate
The discussion focuses on finding an analytical solution for thermal stresses in a rectangular plate with traction-free surfaces and a parabolic temperature change along the y-axis. Initial confusion arose regarding boundary conditions, but it was clarified that all edges are free to move. Participants suggest potential solutions involving functions like cosine and polynomial combinations. They note that while direct stress normal to a free edge is zero, other stress components can still exist. The conversation emphasizes the complexity of shear strains and their impact on stress distribution.
Sargam
Hello everybody,
I am solving a 2D problem of thermal stresses in a rectangular plate in which temperature is changing only y direction. Plate has fixed displacement conditions. Could anyone help me to find out analytical solution of thermal stresses for my problem? Does anyone suggest me where I can find analytical solution?
Thanks in advance.
Sargam
What are "fixed displacement conditions"?
Solutions could be something like a parabola or a cosine in the transverse direction, multiplied by a tanh in the expansion direction. Try a few ones.
Hi,
Thanks for the reply. I have mistakenly mention fixed displacement boundary condition but actually all surfaces of rectangle are traction free (free surfaces). Temperature change is parabolic on y-axis.
Could you please let me know where I can get analytical solution for this problem?
If temperature is uniform along the X axis and all edges are free to move, stress is zero everywhere, whatever the profile is along the Y axis.
In the more general case, try a product of cos(x) and cos(y) with different harmonic periods - but a particular polynomial solution can look good.
I think I can see how you reached that (wrong) conclusion, but what about non-zero shear strains in the plate, and the stresses they create?
The direct stress component normal to a free edge must be zero, but the other stress components along a free edge need not be zero. Axial tension in a rod is a simple (non-thermal) example.
Right!
It must be something like tanh(x) times a polynomial of y.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
