Angle of Intersection of Space Curves
the7joker7
The curves `bar r_1(t) = < 2t,t^(4),5t^(6) >` and `bar r_2(t) = < sin(-2t),sin(4t),t - pi >` intersect at the origin.
Find the angle of intersection, in radians on the domain `0<=t<=pi`, to two decimal places.
Well, I tried to do it in the same way I would with two vectors. I needed to find the dot product and the magnitudes for starters, so...
Dot Product:
(2t)(sin(-2t) + (t^4)(sin(4t)) + (5t^6)(t - pi)
Magnitudes:
sqrt((2t)^2 + (t^4)^2 + (5t^6)^2) * sqrt((sin(-2t))^2 + (sin(4t))^2 + (t - pi)^2)
But...now I'm not sure what to do. Am I even going in the right direction?
you need the tangent vectors at the point of intersection -- do you know how to find these?
I think so...
T(0) = r'(0)/the magnitude of r'(0), so...
r'(0) = <2, 0, 0>
magnitude of r'(0) = sqrt(4) = 2
so
T(0) = <1, 0, 0>
And for the other one we have...
r'(0) = <cos(0), -cos(0), 1> = <1, 1, 1>
Magnitude of r'(0) = 1.732 = sqrt(3)
T(0) = <1/sqrt(3), 1/sqrt(3), 1/sqrt(3)>
Now what?
now you can use the vector identity that relates the dot product to the angle between two vectors to get your answer. I didnt check your work but the tangent vector is:
\vec{T}=\frac{\frac{dr}{dt}}{|\frac{dr}{dt}|}
but it looks like you are on the right track.
I tried that, didn't work...
I tried dot product over magnitudes = cos(theta) and tan(theta), but neither was the right answer.
FTR, the right answer was 2.022.
you're not differentiating the trig terms correctly.
I did it and got the right answer. just be careful
Well, t=0, right?
Derivative of sin is cosine...
So r'1(t) = <2, 4t^3, 30t^5>
r'1(0) = 2, 0, 0
and
r'2(t) = <cos(-2t)*-2, cos(4t)*4, 1>
r'2(0) = <-2, 4. 1>
Now dot product...
(2)(-2) + (4)(0) + (1)(0) = -4
magnitude
2 * 4.5825 = 9.16515139
cos(theta) = -4/9.16515139
theta = 2.022.
Aha! Got it.
Thanks!
r'(t) = <-2, 5t^4, -2t>
r'(0) = <-2, 0, 0>
r'(t) = <cos(3t)*3, cos(-3t)*-3, 1>
r'(0) = <3, -3, 1>
dot product
-6
magnitude
2*4.3588989 = 8.717797887
cos(theta) = -6/8.717797889
theta = 2.33
Why isn't this right?
This is driving me crazy...
It's probably just a stupid minor error, but I swear I did the exact same thing above that I did before when I got it right...
r'(0) = <-2, 0, 0>
r'(0) = <3, -3, 1>
dot product
-6
magnitude
theta = 2.33
Since you did not state the original problem, it is impossible to tell whether that is right or wrong or where you might have made a mistake.
The curves `bar r_1(t) = < -2t,t^(5),-1t^(2) >` and `bar r_2(t) = < sin(3t),sin(-3t),t - pi >` intersect at the origin.
Yes, they do intersect at the origin. In particular, r_1(0)= < 0, 0, 0>. But r_2(0) = < 0, 0, -pi>, not <0, 0, 0>. For what value of t is r_2(t)= < 0, 0, 0>?
r'(0) = <-2, 0, 0>
r'(0) = <3, -3, 1>
No, you have the wrong t.
dot product
-6
magnitude
theta = 2.33
