Angled Projectile Motion Question
13 replies · 3K views
xxlvh
1. An object was thrown up at an angle of 22o from the horizontal. If this object travels 38 m horizontally, what was the speed at which the object was thrown?
angle = 22o
dhorizontal = 38m
g = -9.81m/s2
I have absolutely no clue on how to even go about starting to solve this question...would anyone be able to give me a small hint perhaps on which formula to work with?
Put the intial speed as V inclined at the angle of 22. Split that into vertical and horizontal components. (Note that the horizontal velocity is constant).
Then use your kinematic equations.
If I have the angle and split it into the x and y components, wouldn't I still need at least one velocity given to solve for any of the other sides?
Find the total time for the motion ([itex]s=ut+\frac{1}{2}at^2[/itex]) in terms of V.
Then the total horizontal distance travelled=Horizontal Speed * Total time for the motion
Hmm. The formulas I used were just slightly different, I've never seen that one before...what would the variables of "s" and "u" stand for?
s=displacement
u=initial velocity
Okay, thank you.
And Vi would be...22?
Sorry for all the questions. I wasn't having any problems in the whole unit up until this last question!
xxlvh said:
Okay, thank you.
Vi=initial veritcal velocity=Vsin22.
Alright...I've gotten it to:
t = -2(Vsin22o) / -9.81m/s2
Good.
Now consider horizontal motion.
Horizontal Distance=Horizontal speed * Time
and you have t=(2Vsin22)/9.81 and the horizontal distance is 38
Okay...So 38 m = V x (2vsin22/-9.81)
Are you able to combine the two V's, if one is horizontal and one is vertical?
When I tried that in the next step I have -372.78m=2v2sin 22o...when working through it though, it ends up with the root of a negative number so I'm assuming I made a mistake somwhere. =/
[tex]\frac{-2(Vsin22)}{ -9.81}[/tex]
minus signs cancel out.
and Horizontal velocity=Vcos22.
Solving for V, I got 23 m/s. According to the book that is the correct answer!
This will add 3% onto my overall mark :) Thank you, I really owe you one!
