Angular acceleration and such
In summary, the conversation discusses the acceleration, revolutions, torque, kinetic energy, and angular momentum of a car's engine. The angular acceleration of the car is 180.12 rads-2, and the tangential acceleration of a point on the engine's crankshaft is 3.42 ms-2. The engine makes 139.58 revolutions during the duration of 2.5 seconds. The torque generated by the engine is 1.62 mN, and the kinetic energy of the crankshaft at its maximum rpm is 1492.78 J. Its angular momentum at that time is not mentioned.
warmfire540
53
As you press down on the accelerator of your car you see the tachometer climb steadily from 1200 rpm to 5500 rpm in 2.5 s.
(a) What is the angular acceleration of the car?
(b) What is the tangential acceleration of a point on the edge of the engine’s 3.8 cm diameter crankshaft?
(c) How many revolutions does the engine make during this time?
(d) If the moment of inertia of the crankshaft is 0.009 kg.m2, what is the torque generated by the engine?
(e) What is the kinetic energy of the crankshaft at its maximum rpm? What is its angular momentum at that time?
I like to make sure I'm grasping this:
angular velocity intial and final (wi and wf)
a. wi=125.66 wf=575.96
wf=wi+at
575.96=125.66-a2.5
ang=180.12 rads-2
b.ang=a/r
ang*r=a
180.12*.019=a
a=3.42 ms-2
c.theta=wit+(1/2)at^2
theta=314.14+562.88
theta=877.02 rad
rev=theta/2pi
rev=877.02/2pi
rev=139.58
d. torque=I*ang
torque=.009*180.12
torque=1.62 mN
e. K=(1/2)Iw^2
K=(1/2)(.009)(575.98(^2
K=1492.78 J
I can't spot any conceptual mistake... :)
L=Iw
L=.009*575.98
L=5.18 kg m2/s
I would like to clarify and confirm your calculations for each part of the question:
a) To find the angular acceleration, we can use the formula: angular acceleration (α) = (final angular velocity - initial angular velocity) / time. So, α = (575.96 rad/s - 125.66 rad/s) / 2.5 s = 180.12 rad/s^2.
b) The tangential acceleration is the linear acceleration at the edge of the crankshaft, which can be calculated using the formula: tangential acceleration (a) = angular acceleration (α) * radius (r). So, a = 180.12 rad/s^2 * 0.019 m = 3.42 m/s^2.
c) The number of revolutions can be calculated using the formula: number of revolutions = (final angular position - initial angular position) / (2π). In this case, the final angular position is 575.96 rad and the initial angular position is 125.66 rad. So, number of revolutions = (575.96 rad - 125.66 rad) / (2π) = 139.58 revolutions.
d) The torque generated by the engine can be calculated using the formula: torque (τ) = moment of inertia (I) * angular acceleration (α). So, τ = 0.009 kg.m^2 * 180.12 rad/s^2 = 1.62 Nm.
e) The kinetic energy of the crankshaft at its maximum rpm can be calculated using the formula: kinetic energy (K) = (1/2) * moment of inertia (I) * (angular velocity)^2. So, K = (1/2) * 0.009 kg.m^2 * (575.96 rad/s)^2 = 1492.78 J. The angular momentum at this time can be calculated using the formula: angular momentum (L) = moment of inertia (I) * angular velocity (ω). So, L = 0.009 kg.m^2 * 575.96 rad/s = 5.18 kg.m^2/s.
1. What is angular acceleration?
Angular acceleration is the rate of change of angular velocity in a rotational motion. It is measured in radians per second squared (rad/s²).
2. How is angular acceleration different from linear acceleration?
Angular acceleration is the rate of change of the angular velocity, while linear acceleration is the rate of change of the linear velocity. Angular acceleration is measured in radians per second squared, while linear acceleration is measured in meters per second squared.
3. What is the formula for calculating angular acceleration?
The formula for angular acceleration is α = (ω2 - ω1) / t, where α is the angular acceleration, ω2 is the final angular velocity, ω1 is the initial angular velocity, and t is the time taken for the change in velocity.
4. How is angular acceleration related to angular velocity and tangential acceleration?
Angular acceleration is directly proportional to both angular velocity and tangential acceleration. This means that an increase in either angular velocity or tangential acceleration will result in an increase in angular acceleration.
5. What is the significance of angular acceleration in rotational motion?
Angular acceleration is important in rotational motion because it determines the rate at which the angular velocity changes. This, in turn, affects the magnitude and direction of the torque, which is responsible for causing rotational motion.
