Angular Distance Homework: Solve Δθ in Radians & Degrees
  • Thread starter Thread starter randomjunebug
    Angular
To find the angular distance (Δθ) in both radians and degrees when Bob's hand moves a distance equal to twice the radius of the steering wheel, the relationship S = r * Δθ can be applied. Given that S is twice the radius (2r), the equation simplifies to 2r = r * Δθ, leading to Δθ = 2 radians. Converting this to degrees, Δθ equals 2 * (180/π), which is approximately 114.59 degrees. The confusion arose from misapplying the circumference formula and the relationship between distance and angle. The correct interpretation shows that the angular distance is simply 2 radians or about 114.59 degrees.
randomjunebug
When driving Bob turns the steering wheel so the distance his hand moves on the steering wheel's circumference is equal to twice the radius of the steering wheel. In both radians and degrees, what angular distance (Δθ) did the wheel turn?
S=r*Δθ
C=2∏r
1 rev=2∏ rad=360°
I know the ratio of the circumference to the radius is 2∏. My first attempt I tried to equate the S and C equations. 2∏r=r*Δθ which got rid of r and I did (1/2)(2∏) which just gave me pi and was wrong. I'm not sure how to solve this but I feel like I'm just missing something small.
I tried making up numbers to help me see it. I pretended r was 5. What I want is 2r, which would be 10. So C=2∏r=31.416. If I divide that by 2∏ I get just r. If I divide it by ∏, I get 2r. So it's still wrong and I'm not sure where to go from here. Any help is really appreciated, it bothers me that I'm missing something.
If the drivers hand moves exactly r in distance, then the angle would be 1 radian, from the definition of the radian. So twice that distance gives 2 radians.
So it has nothing to do with pi. Well I feel silly ha.
Thank you for your help.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
