Angular energy vs translational energy
When a rectangular block tips over, it exhibits both rotational and translational kinetic energy upon hitting the ground, depending on the motion of its center of mass. If there is no friction, the block can rotate freely around its pivot point, affecting the distribution of energy between translational and rotational forms. The weight vector always acts through the center of mass, influencing the block's motion. Friction plays a crucial role in determining whether the block will slide or tip, as it can prevent translational acceleration at the pivot. If sufficient force is applied without tipping, the block will slide with translational kinetic energy and no rotational energy.
GnG.Vike13
i don't understand this at all... if we tip over a rectangular block (such that a corner is its pivot), will it have rotational kinetical energy, translational kinetic energy, or both when it hits the ground?
Ask yourself "Is its centre of mass moving horizontally and or vertically with respect to the floor when it actually lands and is it rotating?"
How would things be different if there were no friction between the corner and the table (assuming you placed it just beyond its tipping angle?
What does that tell you about its translational and rotational KE, bearing in mind that the same amount of energy is available in each case.
so the translational kinetic energy is based on its center of mass' velocity and the rotational energy is based on the I of the whole block and w?
and, just to be clear, the weight vector will always come from the center of mass, correct?
also, how would friction play into this? would it be at the axis of rotation, thus causing not torque, but preventing it from making a translational acceleration?
That seems the right idea. But there would be a definite difference if there were no friction. What would the block rotate around if the corner were allowed to slip? Would the cm ever be moving horizontally at all? Would the block take the same time to fall with and without friction?
Your statements about mvsquared/2 and Iωsquared/2 are obviously correct. I think the only way that there would be no translational energy would be if it were just a couple that was applied to the block so that the cm was not moving in any direction. This is definitely not the case here.
okay, it's good to know that i understand this. one more question, perhaps.
what happens if the block isn't tipping over and the frictional force is applied completely on block's bottom side? how do you look at the problem then?
Then, with sufficient force applied, won't it just slide with some translational KE and no rotational energy?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
