Archived Angular magnification and the magnifying glass
The discussion focuses on calculating the distance between the work and the magnifying glass, as well as the angular magnification of the magnifying glass used by an engraver. The initial calculations suggest a work distance of 15.3 cm and an angular magnification of 1.63. However, a correction indicates that the distance should actually be 6.88 cm, leading to a revised angular magnification of 3.63. The importance of using the correct sign convention for image distance is emphasized in the calculations. Accurate application of formulas is crucial for determining these optical properties.
Reservist
An engraver uses a magnifying glass (f=9.5 cm) to examine some work. The image he sees is located 25 cm from his eye, which is his near point. A) what is the distance between the work and the magnifying glass? b) what is the angular magnification of the magnifying glass?
M= (1/f -1/di)N
1/di + 1/do = 1/f
A) 1/25 + 1/do= 1/9.5 do= 15.3 cm
b) m=(1/9.5 - 1/25) 25 M= 1.63
Can some one check/ correct my work, not sure if I'm using the correct formulas. Thank you.
This is a virtual image. Using the sign convention you have, the image distance is negative. So $$\begin {eqnarray*}
\frac 1{d_o}&=&\frac 1f-\frac 1{d_i}\\
&=&\frac 1 {9.5}-\frac 1 {-25}\end {eqnarray*} $$I make that ##d_o=6.88##cm for part (a).
Angular magnification is just ##M=-d_i/d_o##. Not sure what your formula is since you don't define N. In this case I make it 25/6.88=3.63 for part (b).
