oddjobmj
- 305
Given the parametric equations for a satellite in orbit around a spherical mass find angular momentum L in terms of ε, a, k, m, where k=GMm.
Also, find the energy E in the same terms.
Lastly, I can only use the equations provided and "fundamental definitions."
Equations provided:
y=a\sqrt{1-ε^2}sinψ
x=a(cosψ-ε)
t=(\frac{T}{2π})(ψ-εsinψ)
\frac{T^2}{a^3}=\frac{4π^2}{GM}
What I think is necessary and otherwise fundamental:
L=rxp
Not yet sure about the equations for energy that would be considered fundamental...
I believe the first part is relatively straight forward even if it wouldn't otherwise be the most elegant way to go about the problem.
L=rxp
I can find r using a2+b2=c2:
r2=x2+y2
r=\sqrt{x^2+y^2}
r=\sqrt{a^2(cosψ-ε)^2+a^2(1-ε^2)sin^2ψ}
v=\frac{2π}{t} (edit: need correction here; this is average velocity... not sure how to do this without using theta; is the nasty relationship between theta and ψ fundamental?)
I'm given t so:
v=T(ψ-εsinψ)
p=mv
p=mT(ψ-εsinψ)
I can solve for T from the given equation that contains it:
T=sqrt(\frac{4π^2}{GMa^3})
p=msqrt(\frac{4π^2}{GMa^3})(ψ-εsinψ)
Now I would just have to solve for ψ and replace it and get rid of the GM factor using k. Assuming I do my algebra and final cross product correctly does that seem like a sound solution to the angular momentum?
With regard to the energy portion I am a little weary about how to proceed given the requirement to use only fundamental definitions. I have come across a number of formulas for E of elliptical orbits that utilize kinetic energy and effective potential. Could it be as simple as:
E=\frac{1}{2}mv2+\frac{GMm}{r} and plug in the values for v and r that I already solved for?
Thank you for your help!
